Author Topic: 1976 gmc wipers on all the time with key on  (Read 4301 times)
Offline kcwis
« on: December 28, 2016, 02:32:00 pm »
Even with the wiper sw disconnected they stay on,  thought sw had to be grounded but dash sw is plastic,not equipped with delay, washers work fine,hi-low works fine.Ran external ground from motor to battery,no difference.
Re: 1976 gmc wipers on all the time with key on
« Reply #1 on: December 28, 2016, 08:54:37 pm »
Replace the wiper motor
Offline blazer74
« Reply #2 on: December 28, 2016, 09:59:23 pm »
The motor is key on 12v hot all the time. The switch controls the ground. The motor is getting a ground somewhere and staying on, probably internal.
Offline hatzie
« Reply #3 on: December 29, 2016, 04:48:19 pm »
Usually that means the park cam has failed inside the motor.
The armature plug will have three wires.  Power with the ignition and HI LO grounds with the switch. Check the HI and LO wires for continuity to ground with the switch off.  If they're dead, infinite ohms, change the motor.
Sent from my SM-P605V using Tapatalk
« Last Edit: December 29, 2016, 05:48:48 pm by hatzie »
