Author Topic: Windshield frame patch  (Read 16925 times)
Offline AugustD
Re: Windshield frame patch
« Reply #15 on: January 12, 2017, 05:25:31 pm »
That would be great if you had some donor pieces. Any luck with your cab? Your pm box has been full so I couldn't message you
Offline Viking 58
« Reply #16 on: January 23, 2017, 01:55:20 pm »
AugustD
Wow,...looks just as bad as mine did,....(82 C-10)
When I got the door-fender and cowl of ,...I almost cried,....but what the heck......if you love your truck,...get at it.
I found a donor, and started cutting it in pieces...remember that with so much rot,....the a-pillar are most probably rotten a good bit up towards the roof line,...
The pillar are made of 3 pcs sandwiched together and a tough one to work with,..drill the spots and peel back a layer at the time,...
Just don't give up,...
Viking
Offline Viking 58
« Reply #17 on: January 23, 2017, 02:40:06 pm »
here is a few other pic's from the bad rust....
Offline Viking 58
« Reply #18 on: January 23, 2017, 02:42:09 pm »
another one...
Offline kcwis
« Reply #19 on: January 25, 2017, 06:27:12 pm »
Does any one know why the window frame rots,on our 1976 gmc sierra grande the dr and pass side rotted,is it a good idea to put alot of silicone on the w/s rubber after repair?
« Reply #20 on: January 27, 2017, 04:03:18 pm »
Water and salt etc. Not nipping it in the bud will allow it to spread
