Body, Glass & Paint
Windshield frame patch
Topic: Windshield frame patch (Read 16928 times)
AugustD
December 28, 2016, 04:33:50 pm »
I'm looking for a way to patch the bottom of the frame where my windshield sits in. The passenger side corner is in bad shape. I'm looking for ideas or anyone with an old cab willing to cut and sell a piece. Thanks very much
80Chevy4x4
Honey this only costed a couple of dollars!
Re: Windshield frame patch
December 29, 2016, 03:34:17 am »
I am looking on how to fix mine too.
Rattler12
Old Geezer
December 29, 2016, 09:03:08 am »
How big is the hole? Pictures ? I patched 5 holes in the bottom part of mine but they were all in flats and didn't extend into the curves. I cut them back to good metal in a rectangular shape. Drilled a 1/4 inch hole at each end. Spotted welded a tab at each end through the 1/4 inch hole and then cut a piece to fit the original cut out and welded it in place. A little grinding, some metal infused body filler and a fair amount of sanding you would never know a hole was there.
83 C-10 shorty 454, 5spd, 3:73 posi
December 29, 2016, 09:04:58 am »
Post pics if you want the best suggestions for your issue.
AugustD
December 29, 2016, 01:16:36 pm »
Here's what I'm working with
AugustD
December 29, 2016, 01:18:55 pm »
Two more angles
December 29, 2016, 06:04:31 pm »
I would suggest sawzall and amputating the sections you need from a donor. It will be a cleaner job than trying to fix that in my opinion. I cut a section out of a cab for someone on here a while back. Maybe someone on here has a scrapper they can help you out with.
December 29, 2016, 06:07:37 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=14132.75
blazer74
December 29, 2016, 10:17:53 pm »
With that much rot you might have firewall to cowl rot int the seams, how about the cab supports, A pillar door hinge areas.
Might consider looking for another cab.
AugustD
December 30, 2016, 09:45:59 am »
Would you just remove fender and see how bad it is?
1967KaiserM715
1985 GMC K1500 w/ 6.5 TD
December 30, 2016, 11:07:00 am »
Quote from: AugustD on December 30, 2016, 09:45:59 am
No you need to go inside, peek behind the carpet and firewall insulation, wouldn't hurt to remove the glove box either.
Sent from my LGL34C using Tapatalk
Current Vehicles:1985 GMC K10(Daily) 1991 GMC K2500(Daily) 1975 Beetle(not running) 1985 Mercedes 300D(not running) 1952 M35 1967 M715(not running)
1986 Chevy K30(under repair)
DuallyJoe
New Users
December 30, 2016, 11:20:40 am »
I might have a donor cab that I can section for you. I am also in the Pittsburgh area (sort of). I will look tonight and take some pictures for you.
AugustD
Reply #12 on:
December 30, 2016, 11:30:15 am »
Ok thanks. I really appreciate the advice
AugustD
Reply #13 on:
December 30, 2016, 12:34:10 pm »
This is what I've found with some more investigating.
montrosepatriot
Reply #14 on:
January 07, 2017, 03:59:53 pm »
unlike the previous 67-72 generation the squarebody windshield frame and upper cowl panel is in one piece - this illustration shows the windshield frame/upper cowl assembly (OEM #15629646 81-91 (w/hood hinge cutouts and cowl screen provisions); #459891 73-80)
Body, Glass & Paint
