Author Topic: Vortec 5.7 paired to th350?  (Read 6325 times)
Offline jackerekson
« on: January 01, 2017, 11:06:39 pm »
Have a 79 c30 I'm doing a lot of work to, it's getting a 91 front clip solid axles and I shortened the frame to fit a short box, have a 97 burb the tranny went out on so I decided to convert to the fuel injected 350, if I keep the th350 in it what would I need to do to make that work?
project junky
Re: Vortec 5.7 paired to th350?
« Reply #1 on: January 02, 2017, 05:02:49 pm »
The VSS signal
Offline fitz
« Reply #2 on: January 04, 2017, 07:25:12 am »
Painless wiring makes a VSS that attaches between your trans & speedo cable for about $150.
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #3 on: January 04, 2017, 09:59:31 am »
Jags that Run makes a VSS that attaches to the backside of the pinion flange for about $90.
You could get a programmable MegaSquirt ECU for less than a carburetor, and have full control over any modifications you do.  Doesn't need a VSS at all.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
« Reply #4 on: January 04, 2017, 05:39:36 pm »
I should clarify, it won't have a vss signal but that does not mean you necessarily need it unless you are concerned about DTC's being set or TCC operation (if its a TH350c)
Offline SkinnyG
« Reply #5 on: January 04, 2017, 07:20:17 pm »
In my reading, apparently the VSS has a role in cruise tuning, as well as deceleration and makes lower engine speed more stable.  I have no first-hand experience though.
Offline jackerekson
« Reply #6 on: January 08, 2017, 10:34:53 am »
Could I just pull the whole wiring harness out of the burb and lay it into my truck without hooking up the transmission cable or will it throw the ecu off?
project junky
Offline SkinnyG
« Reply #7 on: January 08, 2017, 11:18:57 am »
My understanding is it will throw the ECU off.  A code, plus driveability issues.  But I may be wrong about your particular combination. The project I am wiring up EFI for, needs the VSS for sure.
« Last Edit: January 08, 2017, 11:22:15 am by SkinnyG »
« Reply #8 on: January 08, 2017, 02:40:06 pm »
Is it a TH350 or TH350C? Does it have the square connector on the drivers side?
Offline Sinister.454
« Reply #9 on: January 10, 2017, 12:58:53 pm »
Sucks because youll need to rig up a electric fuel pump...adds $$ and headaches to the job.
Better to buy a crate engine and run the standard manual pump.
Ask me how I know...
