Author Topic: FlameProof Coating my exhaust headers  (Read 5036 times)
Offline plik
« on: January 08, 2017, 02:20:27 pm »
I found a really cool product -- VHT SP102 FlameProof Coating Flat Black Paint Can
The idea is you spray this on your exhaust headers and then it creates a ceramic coating. There are specific instructions you must follow to make sure the ceramic coating cures properly.
However, it's a COMPLETE WASTE OF MONEY!!! :-(
Look what happened to mine.
Re: FlameProof Coating my exhaust headers
« Reply #1 on: January 08, 2017, 02:31:38 pm »
What are the special instructions.  Cranking it and getting it hot is going to be an uneven dry.  I would think they would have you put them in an oven or something.
« Reply #2 on: January 08, 2017, 02:37:38 pm »
Those products are crap. It's worth it to get a true thermal barrier coating done professionally. It will also help your headers last much longer and they also look nicer. I did my entire exhaust system on my 74. Well worth the spend
Offline plik
« Reply #3 on: January 08, 2017, 02:46:15 pm »
Prepare the headers: clean thoroughly, use steel wool to remove any surface rust, finally clean with a grease and wax remover.
Paint headers: I gave mine several coats and let them dry over three days (I live in Arizona, so there's zero humidity)
Cure the ceramic coating: make sure headers are dry, then install them onto the engine. Idle for 10 minutes, let cool 20 minutes. Then, idle for 20 minutes, let cool 20 minutes. Finally, drive for 30 minutes.
I took those pictures right after my 30-minute drive.
Offline plik
« Reply #4 on: January 08, 2017, 02:47:30 pm »
I wish I had. :-(
What did it cost you?
« Reply #5 on: January 08, 2017, 02:53:15 pm »
I am not a fan of VHT in any of their products either I might add. I think all of their stuff is lacquer based too iirc
Honestly I'd have to look for receipts. Can't remember
