Author Topic: Bed rail caps/protectors  (Read 6003 times)
Offline Tommyd11730
« on: January 27, 2017, 10:08:52 pm »
Guys
Does anyone still make a decent set (diamond plate or otherwise) of bedrail protectors.  Looking for a set that will allow me to use the factory holes and not cover them up.
For a 84 standard bed.
Thanks!
1991 K5
1984 K2500
Offline GMCMedic
Re: Bed rail caps/protectors
« Reply #1 on: January 28, 2017, 07:07:58 am »
Guys
Thanks!
They still make them. I saw them on a website that we cant post here.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Offline Tommyd11730
« Reply #2 on: January 28, 2017, 01:08:48 pm »
Thanks, the only ones i see dont have provisions for the stake holes.
1991 K5
1984 K2500
« Reply #3 on: January 28, 2017, 02:56:08 pm »
I'm not sure anyone does with the stake holes but it would be very easy to make your own holes.
Offline Tommyd11730
« Reply #4 on: January 28, 2017, 03:23:27 pm »
Im with you but my fear is cutting into them will start the rusting process that much quicker.
1991 K5
1984 K2500
« Reply #5 on: January 28, 2017, 05:06:24 pm »
I've only seen them in stainless, aluminum or plastic.
Offline 75gmck25
« Reply #6 on: January 29, 2017, 09:20:17 am »
I made my own out of angle iron.  I cut them to length and put a curve on the back end so it matched the bed profile.  Then I marked the cutouts for the stake holes and cut them out with a plasma cutter.  I found some chrome bed tiedowns to put in the cutouts so that you can't see the rough cuts from the plasma cutter.
I was worried about rust so I didn't want to put bolts through the top.  I put a thin rubber material under the top and used stainless steel bolts to attach it to the inside of the bed.  Its been that way for about 8 years and all you can see is wear on the black paint I used.
I also have a headache rack and cargo box, which are bolted right on top of the angle iron bed caps.
Bruce
