73-87 Chevy & GMC Trucks
Hey guys extremely new and need help
Topic: Hey guys extremely new and need help (Read 7841 times)
zay580
February 01, 2017, 09:08:32 pm »
Hi guys like the title says I'm new to chevy and I'm very glad to be here. I got a picture of my 86 c10 350 engine truck got her for a good price. But having a big problem and just need a little guidance the guy I got the truck from replace the engine new carb and everything. My problem is I see a vacuum hose just open right under the carb and have no clue where it goes ? Also having a problem with the truck just cutting off. I have to press on the gas just to keep it crank ? Can it be that hose that's open. I'll post a picture thanks guys for your help.
Re: Hey guys extremely new and need help
February 02, 2017, 10:15:14 pm »
what happened to your old chevy? and post bigger pictures so we can see. vacuum leaks can cause the engine to stall
Rattler12
Old Geezer
February 03, 2017, 10:19:11 am »
Put a rubber cap on it and see if your stalling problem stops. Is the truck stock or did the PO remove all the "factory stuff" ie various vacuum switches etc.
83 C-10 shorty 454, 5spd, 3:73 posi
zay580
February 03, 2017, 10:43:30 am »
I'm at work at the moment I'll try to get better pictures. My old chevy had to be sold sadly didn't have the room when I moved. Rattler12 I tried putting a cap on the hose but nothing changes. I don't feel any suction or air coming from the hose. I spoke with the original owner he stated that he canceled the PCV valve but still have the canister and original harness and wires but not original motor. Could it be that it set for a whole year ?
Timberwolf
February 05, 2017, 11:31:40 am »
When you mentioned that the engine sat for a year, did the carb have fuel in it when it was parked?
Fourxbob
February 05, 2017, 01:00:27 pm »
Looks like the hose would have went to the pcv valve.
Did he make the proper adjustments on the carburetor when he installed the new one? Could just have the idle set too low.
Sent from my LGL44VL using Tapatalk
bd
February 05, 2017, 01:41:39 pm »
Quote from: zay580 on February 03, 2017, 10:43:30 am
...I spoke with the original owner he stated that he canceled the PCV valve....
What does this mean? Did he "hide" the PCV valve from view or eliminate it? PCV is a passive device and very beneficial to engine longevity.
I agree, larger pics are in order.
zay580
March 20, 2017, 10:30:56 am »
Hey guys I know it's been awhile since I been on just to update solve the stalling carburetor needed a good tune . Just installed new dual intake manifold. Just got to play with dizzy and she should be good to go !
North Central Ohio
March 20, 2017, 08:16:01 pm »
Hey zay....your inbox is full
