Author Topic: Carb Help  (Read 5064 times)
Offline 2tone4by
Carb Help
« on: February 02, 2017, 12:58:56 pm »
Have the quadrajet that came on my. 78 chevy 350 that I can't seem to get it right. Do you guys have any suggestions where I can either have mine built or have it swapped I want to stay with the same carb if possible.....thought appreciated
Offline 2tone4by
Re: Carb Help
« Reply #2 on: February 03, 2017, 12:03:20 pm »
Anyone had any expierence with Guaranteed carbs.com ...178.00 exchange with warranty as long as you own it
Offline philo_beddoe
  • 77 C-10
Carb Help
« Reply #3 on: February 06, 2017, 09:37:56 pm »
Or...
http://www.nationalcarburetors.com/lookup.aspx?partnum=nd4207
This is where i got mine. Great service. The carb came with xtra gaskets and they sent me a free base gasket when i changed manifolds. Carb came looking like brand new.
« Last Edit: February 06, 2017, 09:40:56 pm by philo_beddoe »
Offline Stewart G Griffin
Re: Carb Help
« Reply #4 on: February 07, 2017, 08:19:44 pm »
These are just my opinions, so they probably should not be taken as law.   On the other hand, they probably should be taken as law.
1) If it all possible, do not trade the original in as a core;  Keep it.  Because it's correctly calibrated for you application.
2) i would only buy a re manufactured carb or have mine rebuilt at the following:
http://www.cliffshighperformance.com/
https://www.smicarburetor.com/
http://jetchip.com/
https://www.quadrajetpower.com/
i will also go out on a limb as state that i think the Jeg's/summit reman q-jets are acceptable and specifically i would be willing to bet that jeg's #15805 will run really good on your application.   i run this carb now.
Offline redhot1.4
Re: Carb Help
« Reply #5 on: February 15, 2017, 02:09:06 am »
Yes buy a edelbrock carburetor
I've had 2 in the last 15yrs and still a champ.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Re: Carb Help
« Reply #6 on: February 15, 2017, 07:50:51 am »
They are pretty simple to rebuild, why not just rebuild it?
Offline rich weyand
Re: Carb Help
« Reply #7 on: February 15, 2017, 10:04:29 am »
http://jetchip.com/
I'll second all of this.
The Quadrajet is the superior street carb.  It will give better street performance and mileage than anything short of EFI.  It was GM's "universal" carburetor during that period.  The way it was used on so many applications is that it is internally tuned with little pressed-in air bleeds that were drilled to size for the application.
So, if you have one that is set up properly for the application, it will be the best choice.  If you get one that is not set up properly for the application, you are unlikely to ever get it tuned properly.
Hang on to your existing carb, just in case, and consider the sources Stew mentions for a reman Qjet.
And the JEGS 15805 claims to be set up for the application as well.
