Author Topic: door handles  (Read 7232 times)
Offline knuddy
door handles
« on: January 03, 2007, 03:12:00 pm »
hi all,first timer but have been lurking here for a few months.
i have an 86 c10 longbed that is having a ground up resto
and i am about to start the painting.i have stripped the cab
and doors,but i cant for the life of me figure out how to get
the door handles off the little rod that connects them to the
door catch mech.
can anyone help.also has anyone boxed or know of anyone who has boxed the chassis rails on the halftonners.
cheers guys.
Offline roundedline
Re: door handles
« Reply #1 on: January 03, 2007, 02:17:00 pm »
Are you talking about removing the rod from the latch lever?  If so, you need to push back the capture sleeve and pop it out.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline knuddy
Re: door handles
« Reply #2 on: January 03, 2007, 02:49:00 pm »
its the rod that goes into the slot on the doorhandle mech.
the rod has a sort of a nob on the top and at the bottom the rod bends 90 degrees and goes into catch mech.does the rod dissconect at the top or down at the catch mech.there is a spring clip at the top that i took out but that din not work.i think that clip is there for antivibration.
thanks.
Offline roundedline
Re: door handles
« Reply #3 on: January 03, 2007, 03:31:00 pm »
Re: door handles
« Reply #4 on: January 04, 2007, 07:39:00 am »
As Chris said it comes out on the latch end, then you can slide it up and out of the outside handle. There is a spring steel slide clip that holds the rod in. You have to pull the catch back and slide the clip back alittle bit then the rod comes out of the latch.
When I paint most of my Chevys I just unbolt the handle and pull it out of the door a bit, mask it up, and spray, then rebolt it up not disturbing the rod at all.
Offline viperito
Re: door handles
« Reply #5 on: February 25, 2009, 09:24:04 pm »
How do you get a hold of the clip? There's no room to move inside the door at the latch.
Re: door handles
« Reply #6 on: February 25, 2009, 10:04:00 pm »
I flip it up with a long screwdriver and push it down.  It doesn't have to come off to release...
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: door handles
« Reply #7 on: February 26, 2009, 03:56:48 am »
Here's ya a pic of one of the rod for the door lock knob.  a;; the rods come off the same way though.  where the red arrow is, you pry it out to release it and then slide the clip like the blue arrow goes and then the rod will slip out.  to replace it, push the clip back like it was and then just push the rod through it till it clicks and you're done.  the rod you want can be really hard to get to, if you just can't get it you may have to unscrew the whole latch to gain access.  sometimes I can get it without unscrewing the latch, but sometimes I can't.
Offline viperito
Re: door handles
« Reply #8 on: February 27, 2009, 12:56:17 am »
cool. Thank you all for helping me get the door handle off. It was very much appreciated. You know your stuff. I had to loosen the latch mechanism and broke the clip,  maybe I'll do better on the other one. Thanks again.
