Author Topic: Bypass electronic spark control  (Read 10362 times)
Offline jastur323
« on: February 09, 2017, 11:59:21 am »
I know how to bypass the electronic spark control but once you put the two wires together do you plug it back in or leave it unplugged? Thanks
Sent from my SM-G920P using Tapatalk
Re: Bypass electronic spark control
« Reply #1 on: February 09, 2017, 12:22:49 pm »
to bypass it you unplug it, which should only be done for timing. once done you plug it back together
« Reply #2 on: February 09, 2017, 02:09:20 pm »
Are you trying to bypass it permanently or set timing?
« Reply #3 on: February 09, 2017, 02:12:31 pm »
Please include Year, Make, Model etc.. when posting
Welcome to the site.  Do you have carburetion or TBI?
« Last Edit: February 09, 2017, 08:51:14 pm by bd »
Offline jastur323
« Reply #4 on: February 09, 2017, 07:58:50 pm »
Yes I want to bypass the electronic spark control permanently
1983 GMC High Sierra.
« Last Edit: February 09, 2017, 08:51:30 pm by bd »
« Reply #5 on: February 09, 2017, 08:03:12 pm »
Why do you want to do that? But I imagine you can just leave it unhooked
« Reply #6 on: February 09, 2017, 08:59:59 pm »
jastur323, is your 83 High Sierra a California truck with feedback carburetor?
Offline jastur323
« Reply #7 on: February 09, 2017, 09:52:36 pm »
No its not a California Truck and yes it has a carburetor all original with 89000 miles
« Reply #8 on: February 09, 2017, 09:59:51 pm »
Once you connect the black and green distributor pigtail wires together, I believe the distributor connector remains disconnected from the harness running into the ESC module inside the cab.
Here is the source article:  Changing To A Non-ESC Distributor
