Author Topic: Q&A for those who have dropped their trucks or want to drop their trucks  (Read 42081 times)
Going off my other post about what size lift will fit what size tires. I wanted to give those of you guys that for some reason drop your trucks  ;), a post to do the same thing as we did. I don’t know the first thing when it comes to dropping a truck. So I’m just going to edit the post as people reply. But I guess what I need from those that have dropped their trucks is to say what you have done (drop, C-notch or whatever you guys do) and what size tires you can fit. Post pictures also
« Last Edit: February 12, 2017, 09:20:44 am by Irish_Alley »
Re: Q&A for those who have dropped their trucks or want to drop their trucks
« Reply #1 on: February 12, 2017, 09:17:47 am »
Stock height.  17" wheels with same diameter as factory.
« Reply #2 on: February 12, 2017, 09:20:12 am »
2.5" Western Chassis spindles front, 4" Western Chassis drop leafs in back (same truck as above and same tires
Offline MrFiveOh
  • The Local Po-Po
« Reply #3 on: February 13, 2017, 08:56:10 am »
4/5 drop. Eibach drop springs in the front, DJM flip kit in rear (no notch). 275/60/15 tires all around.
1974 C-10 AKA "Smurf"
350/700R4 Hooker Headers 134-A A/C
4/5 Drop - Ridler 650 rims 20x8.5/20x10
Kenwood single din radio 2 IB-Flat Pioneer Subwoofers Rockford Fosgate Power 1000-bdcp amp
Offline 83redrocket
  • New Users
Bell Tech 5”/ 7” drop, Flip kit.  Bonspeed Wheels –  20x8 Front, 22x8 Rear.  Bought truck this way.  No known clearance issues however fully shimmed upper control arm but need more to reach correct camber.  I understand I will need to get offset upper control arm shafts to fix this issue.
Offline irk_miller
  • You've been mostly-dead all day.
5"/8" drop.  2" drop spindle + 3" drop Eibach springs up front.  Flip kit + 2" drop spindles/ frame notch rear.  Belltech Nitro drop shocks all around.  15" rims with 245/60R15 tires up front and 16" rims with 255/65R16 tires rear.
Only dead fish follow the stream.
Offline Razorback93
I know this is an old thread and you might not have the truck anymore but I'm fixing to drop my 86 c10. Curious if you liked the western chassis drop and how it rode? Thanks!
Sent from my SM-A115U using Tapatalk
yes I still have this truck, it is the "73-87chevytrucks.com" truck.  full thread is here: http://forum.73-87chevytrucks.com/smforum/index.php/topic,12120.0.html
Truck rides well, currently about 40K on the suspension, 47K since the LS swap.
I use Western pretty much for all rear drops because they make rear drop springs.  The front is just a spindle, so technically anyones will work, but I just get it all from one place when I can.  Good shocks make a difference too.
Offline Razorback93
Ok great thanks. I looked through your build. Lol way more info than I expected and love the twin turbski setup. I'd like to ls swap mine after this suspension but I'm thinking about just dropping a t56 in with my 400sb for awhile. I need the extra gears that the old  350turbo isn't giving me. Thanks for the reply. This is my 86.
