Author Topic: 4l80 electronic controller ?  (Read 10433 times)
Offline lstoold
« on: February 15, 2017, 10:23:33 am »
4l80 it have the computer to control it ,or ECM control ?if it had can you location it in vehicle.i know i ask funny,i hope your guys help because i do not  want see my truck die in weather
Re: 4l80 electronic controller ?
« Reply #1 on: February 15, 2017, 10:26:09 am »
you have to have a tcu (transmission control unit) or ecm that came with the 4l80e. again the 4l80e only came out in 91 and could have a 350, 454 or diesel. you could find a whole unit and pull the ecm wiring and tbi engine
Offline lstoold
« Reply #2 on: February 15, 2017, 01:32:18 pm »
but if i get 4l80 transmission 4x4 only,and i set up 4l80e with ls 6.0 gm vortec(eng come with ecm,factory harness,i will send ls ecm for they reprogram...and the harness i will send for someone re wire for me)so will  they work together .
« Reply #3 on: February 15, 2017, 01:37:45 pm »
dont know for sure. if the 6.0 came with the 4l80e then the speed sensor is the only thing i think you should have to worry about (besides a reprogram) i cant honestly tell you for sure best thing would be to talk to someone who programs these things. the main issue that i can think of is the output speed sensor on the transfer case.
« Reply #4 on: February 15, 2017, 10:40:45 pm »
If the donor harness was for a 80E it will work as all the wires are there.
squarebody.biz
Offline lstoold
« Reply #5 on: February 21, 2017, 03:30:05 am »
Thanks
