Author Topic: Holley Sniper Fuel System Setup  (Read 80809 times)
Offline BlackTomC
« on: February 19, 2017, 01:47:08 pm »
Hey guys, I've got a bone stock 76 GMC suburban, just picked up the Holley Sniper TBI kit and wanted to know what needed to be done to the gas tank in order to make this thing work. A friend on mine mentioned installing a different sending unit, I can hook it all up I just don't know what to get. Thanks.
The bottom line has dropped
Offline Stewart G Griffin
Re: Holley Sniper Fuel System Setup
« Reply #1 on: February 19, 2017, 04:34:42 pm »
How much lbs. does the Sniper system require for the pump?
Offline BlackTomC
« Reply #2 on: February 19, 2017, 09:43:06 pm »
Looks like 60psi, kit was the "master kit" so it came with fuel line, filters, the pump and tons of different fittings
« Last Edit: February 19, 2017, 10:14:28 pm by BlackTomC »
« Reply #3 on: February 20, 2017, 06:01:28 pm »
If you have a stock 76 setup, then the simplest thing may be to use a fuel pump reservoir and not even mess with the stock tank.
« Reply #4 on: February 20, 2017, 08:47:02 pm »
Run a 87-up sending unit and run a EP381 pump in it.
« Reply #5 on: February 20, 2017, 10:51:52 pm »
But then, what about baffles?
« Reply #6 on: February 20, 2017, 11:13:10 pm »
I personally would run hydramat in the bottom of it.
« Reply #7 on: February 21, 2017, 06:46:56 pm »
Wow.....ok.  So i guess you don't need baffles anymore:
https://www.holley.com/products/fuel_systems/hydramat/
« Reply #8 on: February 21, 2017, 07:24:27 pm »
You don't need them anyway if you keep the tank over 1/4
« Reply #9 on: February 22, 2017, 09:27:04 pm »
Ditto on what Vile stated.  Hundreds of these running around without them.
Just don't do any parking lot cone races in it and expect it not to slosh.
Offline BlackTomC
« Reply #10 on: September 12, 2017, 10:21:39 am »
Quick update guys, the Sniper has been installed, the Suburban runs incredibly well. Amazing throttle response, zero hesitation during startup/idle, accelerates much faster now. Thanks to the folks on this forum who put up with all my questions regarding the build.
Offline fitz
« Reply #11 on: September 12, 2017, 05:15:10 pm »
Did you run the inline pump or install one in the tank?
Offline BlackTomC
« Reply #12 on: September 13, 2017, 09:17:24 am »
I ended up installing an inline pump (included with the Holley Sniper Master Kit), came with all the fittings, pre-post fuel filters and tons of hose/hose clamps.
Exceeded my expectations.
Offline Boonie
« Reply #13 on: September 14, 2017, 11:31:19 am »
any pics of the installed unit? looking into one of these for my 74. according to holley, I can use this system and still use the stock air cleaner for a stock look.
Offline Smokehouse
« Reply #14 on: September 01, 2018, 03:26:34 pm »
What mileage are you getting now with the efi kit
You are not that hot to be that bitchy.
