Author Topic: 73 C10 Rear Disk Brake Conversion  (Read 4963 times)
Offline c10rick
« on: February 21, 2017, 06:34:05 pm »
Is there a later model rear disk setup that will mount on a 1973 C10?
Thanks.
Re: 73 C10 Rear Disk Brake Conversion
« Reply #1 on: February 22, 2017, 09:28:46 pm »
Yes and NO.  The ones that would have already be picked from the junk yard.
Serveral companies make kits for these now.  SSBS, Little Shop, CPP, etc.
Offline c10rick
« Reply #2 on: February 23, 2017, 01:45:59 pm »
Thanks for your response.  This little project's winding down. Realizing an after-market setup is about $600 or $800, I'll probably leave the drums on.  I recall about ten years ago converting my 68 Ford.  The twin I beams and all the hardware were about $300 at the wrecking yard.  Doesn't look that simple this time.  I just don't like drums.
« Reply #3 on: February 23, 2017, 07:15:50 pm »
You can get Captian Fab's brackets and run front calipers on the rear and an Astro AWD front disc with front hoses if you want to try and do a cheap version.
It will not have a parking brake.  I have this setup on mine except I am using dual piston calipers from Wilwood.
Offline c10rick
« Reply #4 on: February 23, 2017, 09:19:02 pm »
Thanks.  I'll take a look.
