Author Topic: Wiper module  (Read 16323 times)
Re: Wiper module
« Reply #15 on: March 06, 2017, 09:09:37 am »
...It shuts off when i unplug the wiper switch and when i plug it back in they operate again.  Even plugging the switch up without the module same thing....
Did a lil bit more diagnosing and found without the module connected everything works fine....
What changed since yesterday?  Are you certain there isn't compromised wiring between the delay module and the wiper motor that shorts or grounds intermittently as the harness is moved around?  Make sure there isn't any conductive "debris" between the terminals of the harness connectors.
Offline dieselman123
  • professional
Re: Wiper module
« Reply #16 on: March 06, 2017, 09:19:40 am »
I did all of that removed fuse panel and moved wires arounds nothing changed. I can blow the wires off wit air and see if it changes anything
Gotta clean my back windshield cause I'm too busy kicking up dust
Re: Wiper module
« Reply #17 on: March 06, 2017, 09:30:53 am »
If all of the external wiring is healthy and correct, and the problem occurs ONLY with the delay module installed, replace the delay module.
  • professional
Re: Wiper module
« Reply #18 on: March 06, 2017, 09:37:32 am »
Do you kno if anyone makes the module brand new or do i need to keep loking in the junkyards
. But one thing  i did notice the old motor has a ground strap made on the motor itself and the new one doesnt could that b an issue also the only thing that changed is that i removed the grey wire from switch thats all
« Last Edit: March 06, 2017, 09:54:44 am by dieselman123 »
Re: Wiper module
« Reply #19 on: March 06, 2017, 11:04:10 am »
Are you saying the gray wire was still disconnected from the motor when you removed the module from the circuit?
  • professional
Re: Wiper module
« Reply #20 on: March 06, 2017, 11:37:57 am »
When i removed grey wire the motor stopped running and plug the grey wire back it started running agian. What is the pink wird for i javd voltage at that wire wen key is on.
Re: Wiper module
« Reply #21 on: March 08, 2017, 09:03:48 am »
Perhaps, reading through Wipers won't turn off 1985 will help you get a handle on the problem.  The basic system between the model years is the same.
  • professional
Re: Wiper module
« Reply #22 on: March 09, 2017, 06:13:56 am »
Thanks bd. Found the problem it was the delay module. When i plug it in it grounds the low circuit for some odd reason. But if i plug just the switch in everything operates as is should. Just dnt have pulse as if right now :'( a new on i 173 dollars so i will be saving up for one. Thanks  again bd for all your help
Re: Wiper module
« Reply #23 on: March 09, 2017, 06:35:52 am »
You can rebuild yours
  • professional
Re: Wiper module
« Reply #24 on: March 09, 2017, 05:16:06 pm »
How do i go by doing that is there a video or instructions on how
