Author Topic: Painting plastic door panels  (Read 12855 times)
Offline kcwis
« on: March 09, 2017, 07:47:48 pm »
Any tips for painting faded door panels,interior trim?
Offline kcwis
Re: Painting plastic door panels
« Reply #1 on: March 09, 2017, 07:48:40 pm »
Painting interior trim for 76 gmc sierra grande
Offline gunrac
« Reply #2 on: March 09, 2017, 10:40:17 pm »
lot of times floor wax does the trick
Never Apologize..........as it shows signs of weakness
Offline Dr_Snooz
« Reply #3 on: March 10, 2017, 11:07:19 pm »
I've heard good things about Krylon's plastic paint.
Offline GMCMedic
« Reply #4 on: March 11, 2017, 07:43:49 am »
SEM colorcoat
Sent from my SAMSUNG-SM-G920A using Tapatalk
Offline OldGray
  • Ne'er-do-well
« Reply #5 on: March 11, 2017, 01:05:48 pm »
I used Duplicolor Vinyl and fabric paint.  Works GREAT.
1979 Chevrolet Bonanza / 305 / LWB
Offline 86chevytrk
« Reply #6 on: March 11, 2017, 01:48:34 pm »
I've used the same thing only I cleaned the plastic real good with dish soap and used adhesive promoter before I sprayed the color. 5 years later still like the day I sprayed it. Used it on my dash and my steering column. Was worried about key scratches but seems to hold up
Offline Monkey Uncle
« Reply #7 on: March 11, 2017, 03:00:16 pm »
I used Krylon plastic paint on my vinyl shutters last fall.  So far, seems to be holding up well.
Offline AZ4X4SQBDY
« Reply #8 on: March 12, 2017, 12:21:10 pm »
This is how I do it and the only thing I'll add is I use a gray scuffle with the soap when cleaning it as a fine abrasive. Your goals to remove all dirts, oils, and silicon from the surface, the adhesion promoter I suspect melts the plastic slightly in order for the new paint to really bond with it.
The key to it is the preparation.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Offline OldGray
  • Ne'er-do-well
« Reply #9 on: March 13, 2017, 02:04:59 pm »
Bingo - prep, prep, prep.
I have also used the Duplicolor to paint an old vinyl motorcycle seat.  I took it from grey to black and you couldn't even tell.  I did not use any adhesion promoter.
Offline c10rider
« Reply #10 on: March 15, 2017, 07:38:54 pm »
Offline hwh
« Reply #11 on: March 25, 2017, 10:47:15 pm »
I used sem paint on headliner trim turned out great. Cleaned them with ajax, dawn. The sem prep cleaner. The sem paint 5 light coats
Offline bedwards
« Reply #12 on: March 26, 2017, 09:24:42 am »
I've used SEM paint on old arm rests out of the junk yard to make them match in a 59 Edsel and it has worked well for 3 years now. Once again, follow directions and clean the surface well.
