Author Topic: Glove Box Latch  (Read 5598 times)
Offline gconcilio
Glove Box Latch
« on: June 26, 2006, 01:56:00 pm »
How do you remove the latch from the glove box door?  I have the type that does not use a key to lock, it just latches the door shut.
Offline Nikodemus
  • Constantly broken
Re: Glove Box Latch
« Reply #1 on: July 23, 2006, 11:58:00 am »
Good luck...I had the same one in my truck. I tried to take it off and ended up braking the thing. >:   Got a new one from Chevy Duty for 15$.
Edited by: roundedline at: 7/25/06 5:27 pm
Offline shaved80
Re: Glove Box Latch
« Reply #2 on: July 23, 2006, 12:19:00 pm »
something along the lines of pushing that, twisting that, then pulling this... hope that helps
Offline bfofish
Re: Glove Box Latch
« Reply #3 on: July 23, 2006, 07:11:00 pm »
if you are removing the latch while the glove box is still in the truck start by turning the latch counter clockwise until it is loose (you will see it unthread) then hold the inner half of the latch turn and pull the outer half until it releases.  putting it back together is another battle.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Glove Box Latch
« Reply #4 on: March 21, 2007, 08:32:00 pm »
You stick a paperclip (straightened of course) in the hole and it will loosen the knob....it has been a while, don't remember the details, but just play with it and you'll see it will come off.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
