73-87 Chevy & GMC Trucks
Legitmate Wire Harness?
Topic: Legitmate Wire Harness? (Read 5587 times)
Spool
March 30, 2017, 12:39:59 pm »
Hey Guys,
Came across this on Ebay while picking up a wiring diagram.
I thought these wire harnesses were about $600.
http://www.ebay.com/itm/1973-1982-Chevy-GMC-Pickup-Truck-Wire-Harness-Universal-Wiring-Kit-21-Circuit-18-/141610254124?hash=item20f8a0ff2c:g:mQcAAOSw5cNYQCWk&vxp=mtr
Is this sufficient or is it crap?
Re: Legitmate Wire Harness?
March 31, 2017, 05:35:27 pm »
at first i was skeptical cause of the "universal" but it seams like its made for our trucks and it can be universal
80Chevy4x4
Honey this only costed a couple of dollars!
April 01, 2017, 05:08:39 am »
look at his feedback...it is actually really good with as many sales that he has had.
1967KaiserM715
1985 GMC K1500 w/ 6.5 TD
April 01, 2017, 10:05:23 am »
Universal, looks like a cut and add terminal ends, for the price it seems really good. $600 ones are typically made just for that car and all ends are typically terminated with the correct connectors.
Sent from my LGL34C using Tapatalk
Current Vehicles:1985 GMC K10(Daily) 1991 GMC K2500(Daily) 1975 Beetle(not running) 1985 Mercedes 300D(not running) 1952 M35 1967 M715(not running)
1986 Chevy K30(under repair)
April 01, 2017, 10:24:54 am »
I would ask to see if it appropriately mates with the bulkhead connector. Universal ones typically will not have plug n play compatibility. I bought a 73-87 painless harness for my 74 which had the glass fuses and was too old to bother salvaging. My intent was to build my own harness however my time is more valuable then saving a few bucks. I can honestly say the actual 73-87 harnesses are worth the $ but realize they do not come with everything still. Door harnesses, engine compartment harness, ECM etc are typically not included in these kits. I would check with Chris and see what kind of deals he can get you since he is a dealer for AAW before you pull the trigger.
Spool
April 02, 2017, 11:52:20 pm »
From your experience, is my bulk connector even salvageable?
Painless does certainly seem like the preferred way. There are others in the same price range, but I notice the 600-700 ones will come with the bulk connector and the cheaper ones do not. (Among other things maybe, I'm not yet familiar to be sure)
http://sohiperformance.com/i-1928395.aspx?gclid=Cj0KEQjwwoLHBRDD0beVheu3lt0BEiQAvU4CKlpyRttsqtLeRXMrarbShfStr_F8iyjZ6KYwZEwYt6oaAoO_8P8HAQ
You had mentioned the ECM, they had those in the 73 and 74?
I just found this illustrative walk through of a Nova re-wire. Pretty interesting, honest and informative.
Thought I'd share
http://www.hotrod.com/articles/1208phr-new-painless-performance-wiring-harness-for-project-nova/
Last Edit: April 03, 2017, 12:17:09 am by Spool
April 04, 2017, 06:02:55 pm »
lol no ECM however the wiring harness they sell encompasses the 73-87 span. The bulkhead connector is part of the fuse panel
