Author Topic: 1406 install on 86 C10 required parts  (Read 3543 times)
Offline bamachamp2013
« on: April 07, 2017, 10:05:52 am »
I know this is not going to be a new subject but I have had issues finding a post from anyone that has all the information that seems to be correct.
I recently acquired a c10 from a family friend. The carb that was on it was totally trashed from whoever did work on the truck for them. I have already ordered and recieived the 1406 to replace it, however I am having issues finding all of the documentation letting me know what parts I will need to make everything on my truck hook up to it. I do have the 350 trans on it, I already have the throttle adapter. I do not know what to do transmission kickdown delete.
Thanks,
Corey
Re: 1406 install on 86 C10 required parts
« Reply #1 on: April 07, 2017, 05:41:50 pm »
Not enough info. What transmission do you have? Is your engine currently setup up with spread bore, square bore, q-jet?
Generally speaking you need the base gasket, throttle cable/tv bracket assembly, post studs, return springs, fuel line, clamps, inline filter, fitting for brake booster vacuum, vacuum hose, air cleaner and or spacer, possibly an adapter plate. Need more info
Offline PushrodV8
« Reply #2 on: April 07, 2017, 06:07:25 pm »
+1 for VileZambonie's post.
The #1 thing is the intake situation. I'm not a fan of adapter anythings, can you find a used intake on Craigslist for $40 or $50?
All the little things (adapters \ gaskets \ hose clamps) add up quickly.
