Author Topic: Cell phone charger question  (Read 6071 times)
« on: April 24, 2017, 02:40:50 pm »
In all of my trucks I've always had issues with when charging a cell phone it interferes with the radio. Has anyone came up with a solution to this? I'm in my 02 right now and still have this issue
Re: Cell phone charger question
« Reply #1 on: April 24, 2017, 04:06:23 pm »
I hear that when a persons phone is bugged that happens.... JK.  Mine never has a problem
Offline MrFiveOh
  • The Local Po-Po
« Reply #2 on: April 24, 2017, 04:29:11 pm »
I had a similar issue but with bluetooth. I ended up resetting all my bluetooth and network preferences and be sure wifi connection wasnt attempted on open networks. Ive never had an issue with charging.
1974 C-10 AKA "Smurf"
Offline LTZ C20
« Reply #3 on: April 24, 2017, 07:03:52 pm »
Never had an issue with my square and don't have an issue with my 02 either.
Sent from my SAMSUNG-SM-G890A using Tapatalk
LTZ Cheyenne C20
« Reply #4 on: April 24, 2017, 08:06:29 pm »
You need to check your grounds and or add auxiliary grounds. Make sure wires are not routed near or parallel to any other electrical devices or ignition system. Make sure you don't have a cheap charger. Try someone else's and see if it still does it.
Offline ehjorten
« Reply #5 on: April 27, 2017, 11:11:05 am »
Have bluetooth and Ipods connected to Pioneer head units in both of my square bodies and charge my phone via the cigarette lighter.  Never had an interference issue.
-Erik-
Offline Lifted1
« Reply #6 on: May 09, 2017, 12:06:39 pm »
83 gmc c1500. cheapo usb/cigarette lighter adapter charger from gas station. lights up when plugged in confirming good contact. no radio interference and charges fine.
I think my antenna is in my windshield though. i have no exterior antenna. i get great reception. perhaps you have an exterior antenna with a wire running behind the ashtray??sry cant help more
« Reply #7 on: May 10, 2017, 04:50:18 pm »
on my in my 91, 94 and 02 chevy trucks i have the issue and each on the antenna is in the fender. i dont think my 04 impala had this issue and the antenna was in the rear window
