Author Topic: 87 distributor adj screw location?  (Read 3941 times)
Offline Halogin13
« on: April 30, 2017, 03:49:07 pm »
Hi all... where is the distributor adjustment screw on a 5.7l 350 w TBI? I'm feeling a little stupid here... pics if possible??
1987 V10 P/U
Offline Chuck Step-a-side
Re: 87 distributor adj screw location?
« Reply #1 on: May 02, 2017, 06:28:41 pm »
If you're looking for the bolt that you loosen to adjust your distributor timing, it's located under the leftside of the distributor .
Offline srozell
    • My 1980 Chevy
« Reply #2 on: May 03, 2017, 01:31:00 am »
You'll see it easier if you pull off some of the vacuum hoses and stuff adjacent to your distributor.
It's a 9/16 bolt, and you'll need a box-end wrench to access it. Once it's loose, (and you've marked your distributor location,  you can twist the distributor for better access.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
« Reply #3 on: May 03, 2017, 05:12:53 am »
Passenger side base of the distributor. Make sure you are following the proper timing procedure and put the EST in bypass mode when you set the timing.
Offline Halogin13
« Reply #4 on: May 03, 2017, 10:45:36 pm »
Thank you all... major baby brain was kicking in that day😂
1987 V10 P/U
