Author Topic: V-Belts and routing 85 C30 5.7L w/AC  (Read 28424 times)
Online zieg85
« on: May 14, 2017, 08:29:27 pm »
The fan belts on my 85 C30 are wrong.  I think the AC and PS belts are on wrong and I think they are reversed.  Does anyone have the belt routing and sizes for the AC and PS belts.  Thanks in advance
Online zieg85
Re: V-Belts and routing 85 C30 5.7L w/AC
« Reply #1 on: May 15, 2017, 06:42:24 pm »
I got to looking in my book and came across these.  My RPO sticker says it is a LT9.  What does all the abbreviations mean.  All I have is AC PS/hydraboost and alternator.  HD emissions so nothing else on it.
« Reply #2 on: May 15, 2017, 08:25:58 pm »
Usage Codes:
A/C = Air Conditioning
A.I.R. = Air Injection Reactor (Smog Pump)
EXC = Except
FR CR/SHF = From Crankshaft
GEN = Generator (Alternator)
H4D = Spring Actuated Emission Control with Cast Iron Exhaust Manifolds (Heat Riser Valve)
P/S = Power Steering
P/S/B = Power Steering / [HydroBoost] Power Brake
W/ = With
W/P = Water Pump
Online zieg85
« Reply #3 on: May 15, 2017, 08:44:48 pm »
Usage Codes:
EXC = Except
W/ = With
W/P = Water Pump
Many thanks sir
Offline Pearlmoto
« Reply #4 on: May 16, 2017, 10:35:34 am »
The LT9 in my 1986 K30 took the following part numbers, they also go on in this order if I remember correctly:
AC Delco
15400 - Power steering pump
15555 - Power steering and AC
5K435 - Alternator
15440 - air pumps
« Reply #5 on: May 16, 2017, 12:27:19 pm »
