Author Topic: Kick panel speaker pod warning.  (Read 7891 times)
Offline SinisterC10
« on: May 16, 2017, 08:04:06 pm »
Just a heads up to everyone but the speaker pods that are sold on the site WILL NOT work with aftermarket kick panels, only the original OEM ones.
« Last Edit: May 16, 2017, 10:44:25 pm by SinisterC10 »
Online Captkaos
Re: Kick panel speaker pod warning.
« Reply #1 on: May 16, 2017, 09:11:40 pm »
That is 100% correct.  Who's aftermarket kick panels did you use?  Who is the manufacturer?
Offline SinisterC10
« Reply #2 on: May 16, 2017, 10:44:59 pm »
Not sure who makes them but I bought them from Brothers.
Offline SinisterC10
« Reply #3 on: May 17, 2017, 06:17:08 pm »
Ok I talked to Brithers and they told me that the kick panels are made by Cheyenne Pickup Parts
« Reply #4 on: May 18, 2017, 07:17:37 am »
I have a set of the ones sold here, I also have two other sets from different brands. These are the only ones that I've seen that work with the factory kick panels. The other ones I have are full replacement ones not intended to work with the factory kick panel. How does the aftermarket panel you have vary from the factory one? Is it that far off?
Offline SinisterC10
« Reply #5 on: May 19, 2017, 07:39:53 pm »
The ridges (walls) around the bottom portion are thicker then the originals.
Online Captkaos
« Reply #6 on: May 30, 2017, 08:57:20 pm »
Do you have pictures of them?
