Author Topic: Where to start the build  (Read 6566 times)
Offline Fermentedwaste
« on: May 26, 2017, 05:03:04 am »
 Gonna be starting a 1st time build here soon 87 short bed. What direction do you guys plan a build as far as doing the driveline/suspension/frame work before or after bodywork. Gonna be c-notching putting in a 454/4l80 and body needs a few panels and a floor pan welded in. Space is kind of limited in a two car garage. Any good info is appreciated. Thanks in advance.
Offline hwh
Re: Where to start the build
« Reply #1 on: May 26, 2017, 01:59:11 pm »
I would get all underneath done. Frame, suspension, etc. Then paint and body. The motor, tranny. Then interior last. Just my opinion.
« Reply #2 on: May 26, 2017, 03:20:44 pm »
depending on where you live you might need to treat the underside for rust from salt
Offline srozell
    • My 1980 Chevy
« Reply #3 on: May 26, 2017, 03:54:53 pm »
I think it mostly comes down to your approach.
If it's staying in your shop until it's done, then strip it right down to the frame, and work back from there.
If you plan on driving it while you restore it, then my approach is to start with the most critical issues and finish with the cosmetics.
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
« Reply #4 on: May 26, 2017, 06:09:49 pm »
Right. Yea I planned on keeping it in the garage. This helps shooting the ideas out there. Trucks in swfl now was up by you Irish. North east md. Think Ima strip it do the frame stuff and setup the motor n trans then body work. Thanks for some ideas guys.
« Reply #5 on: May 26, 2017, 07:27:11 pm »
My suggestion is do all of the major body work, strip it down, build the suspension, drivetrain etc and put body back together. Doing body work over a fresh new engine, frame, suspension etc leads to ugliness.
« Reply #6 on: May 27, 2017, 12:16:17 pm »
That's a good point vilezambonie. Thanks for the info guys.
« Reply #7 on: May 27, 2017, 12:18:29 pm »
Might do the bodywork until primer then start the frame a motor then paint it last.
