Author Topic: Ventwindow seal wrinkles  (Read 6954 times)
Offline gntblue
« on: May 27, 2017, 09:53:20 am »
I recently installed new vent window seals that I purchased from this site.  The seals fit pretty well but in the lower rounded corner of the seals have several wrinkles that I can't seem to eliminate.  The seal is yhe outer portion that seals the vent frame to the body.  Can anyone give me some ideas of how to fix this so that the seals will lay flat and seal properly?
Thanks
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Ventwindow seal wrinkles
« Reply #1 on: May 27, 2017, 07:17:48 pm »
I had no issues with mine-I started at the upper top corner-started working in seal, then switched to bottom corner, working back to top. It took a little more work to make sure the seal seated in the round corner, but it did fit.
Did you triple check and made sure you bought the right seal?? I almost got the wrong ones for my truck because it was a split year truck-plus I was using different vent Windows.
 1986 Chevy K30(under repair)
« Reply #2 on: May 27, 2017, 07:18:23 pm »
« Reply #3 on: May 30, 2017, 04:12:48 pm »
Can you post pics of what you are talking about?
« Reply #4 on: May 30, 2017, 06:16:10 pm »
Try resetting them and pulling them up at the top. If they still look like lasagna, tape them down if they are installed and go over those areas carefully with a heat gun. You should be able to train the areas to fit.
Offline gntblue
« Reply #5 on: June 14, 2017, 12:07:51 pm »
Attached are two photos of what I am talking about.  Yes they are the correct seals as they were purchased from the site and I verified that I had the correct ones with the administrator.
This truck has been garage kept and is about to go for inspection.  Do you think having it out in the sun will help these even out?  Or if you guys think I should use the tape method please let me know what type of tape to use.
Thanks
« Reply #6 on: June 14, 2017, 07:33:54 pm »
Please email these pictures to me (webmaster@73-87chevytrucks.com) and let me get back with you.
Offline gntblue
« Reply #7 on: June 15, 2017, 12:22:38 pm »
Chris
I just emailed these to you.
« Reply #8 on: June 20, 2017, 07:49:27 am »
The lip that is wrinkled should be inside the opening of the door not outside of it.  You need to remove the vent and reinstall it with the lip inside the door.  see attached.
