Author Topic: Fuel tank swap  (Read 12861 times)
Offline chiefmiller84
Fuel tank swap
« on: May 29, 2017, 04:19:36 pm »
I did a search on here and couldn't come up with anything. Has anyone swapped out their dual tanks and put a tank in between the rear frame rails where the spare tire used to sit, like on the suburbans and blazers?
Re: Fuel tank swap
« Reply #1 on: May 29, 2017, 06:27:35 pm »
Offline hwh
Re: Fuel tank swap
« Reply #2 on: May 30, 2017, 08:53:57 am »
I did on my build I used the suburban mounts that go front to back across frame.
Re: Fuel tank swap
« Reply #3 on: May 30, 2017, 06:34:38 pm »
So you didn't have to do all the things cptkaos did in his build above?
Fuel tank swap
« Reply #4 on: May 30, 2017, 06:35:43 pm »
http://www.captkaoscustoms.com/blazertank.html
Wow, that's a lot more involved than I thought. Still doable though. This is an awesome build!
« Last Edit: May 30, 2017, 08:13:28 pm by chiefmiller84 »
Re: Fuel tank swap
« Reply #5 on: May 30, 2017, 07:54:29 pm »
not really that involved, just moving braces around and getting an angle bracket.
Here is the same process on my R10 Driver with an LS swap:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12120.msg190717#msg190717
