Author Topic: Fuel Gauge Not moving at all  (Read 8030 times)
Offline MrFiveOh
  • The Local Po-Po
« on: June 01, 2017, 09:36:21 pm »
So i've done some research on here and cant find a post with my issue. Most issues are a pegged fuel gauge or something similar.
My issue i've run into is my fuel gauge doesn't move at all. I have removed the ground from the tank and no change to the gauge. At one time my fuel gauge did work however empty was at 1/4 and full showed past "F'" all the sudden one day the gauge stopped registering. I'm not sure what other steps to take.
1974 C-10 AKA "Smurf"
Offline Jeffs_sledz
Re: Fuel Gauge Not moving at all
« Reply #1 on: June 02, 2017, 01:27:27 pm »
Sounds like a fuel level float issue. I would take the sending unit out of the fuel tank and check it. May be that the float has a leak or come off entirely. I've had that happen on a couple trucks now. Or it could be the sending unit itself that's the problem
1973 Chevy c20
1973 Chevy c30 crew cab dually
Offline FlatBlack77
« Reply #2 on: June 02, 2017, 01:33:20 pm »
I had a similar problem on my 77 the gauge would get stuck around 1/4 tank randomly and the only thing that would fix it would be a hard slamming on the brakes. eventually that stopped doing the trick and it froze all together so i replaced the float/sending unit deal and that fixed the issue completely. just something to try
Offline srozell
    • My 1980 Chevy
« Reply #3 on: June 02, 2017, 01:44:34 pm »
Quote
Hahahaha.. That was the funniest thing I've read today.  ;D ;D ;D
1980 K20 "Camper Special"
1969 K20 Step Side
http://myuglytruck.wordpress.com/
« Reply #4 on: June 02, 2017, 06:59:05 pm »
Removing the ground wire won't help you. Pull the sending unit wire and with the key on observe the gauge.
Offline MrFiveOh
  • The Local Po-Po
« Reply #5 on: June 02, 2017, 09:12:18 pm »
Ok will pull sending unit wire. Just fyi, the gauge doesn't move at all regardless of the tank empty or full, just stick at 1/4 if I wasn't clear before.
Offline MrFiveOh
  • The Local Po-Po
« Reply #6 on: June 04, 2017, 08:32:41 am »
So  haven't been able to pull the sending wire yet, however I did check to see if I was getting power at the gauge so I pulled the gauge out and checked ohm readings. On my ohm reader I have option of 200, 2,000, 20k, 200k and 2000k.
I set it on 200 since its the lowest reading and I know the range is supposed to be between 0-90. When I check numbers in getting anywhere between 135-160. Not sure what that means but I'm getting some kind of power.  I would get those ranges dependent on how I put the red and black pokers on the metal tabs.....?
