Author Topic: Trans hits only 3 positions  (Read 11797 times)
Offline kingmu
« on: September 01, 2005, 11:02:00 pm »
My shifter lever is disconnected from my auto trans. Underneath I can turn the trans lever manually, but I can only hit three positions! Anyone know why?
Offline roundedline
Re: Trans hits only 3 positions
« Reply #1 on: September 06, 2005, 01:23:00 pm »
Offline kingmu
« Reply #2 on: September 10, 2005, 12:35:00 am »
Yes, I have disconnected the rod that connects the shifter on the steering column to the trans. Then I can twist the arm on the trans into three posistions. What is odd is that I can roll the truck freely back and forth in each position.
Offline roundedline
Re: Re: Trans hits only 3 positions
« Reply #3 on: September 12, 2005, 09:52:00 am »
What does the transmisison pan look like?
It the driveshaft installed?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline kingmu
« Reply #4 on: September 16, 2005, 08:55:00 am »
The trans pan has a slight dent in it from where I improperly jacked it up. So that might be the problem?
The driveshaft is installed.
Offline Ziptar
« Reply #5 on: September 17, 2005, 10:58:00 am »
I think Chris meant what shape is the pan so we could figure out type of transmission it is.
Check here Transmission Identification & Decoding
Offline roundedline
« Reply #6 on: September 19, 2005, 09:00:00 am »
Yes, that is what I was asking.  What transmission do you have?
Project Su
Jimmy 2WD Project
Offline kingmu
« Reply #7 on: September 19, 2005, 04:33:00 pm »
Oh, sorry, it's a THM350.
