loss of oil pressure
Topic: loss of oil pressure (Read 5347 times)
muleystruck
June 30, 2017, 11:11:30 am »
my truck is an 86 Scottsdale with a 4.3 and mm7 trans. coming home from work I lose oil pressure. I shut it off, waited a while, started back up, knocking, shut down again. called my bro to bring his trailer, took about an hour or less. had to start it to get on trailer and oil pressure is fine. hauled it home anyway. unloading the truck had to start it, still normal oil pressure. I know the pickup tube could be stopped up then releasing the blockage. this hasn't happened before and I'm concerned about driving the truck. don't want to damage the motor. should I pull the pan and check if trash is present before driving it again? I don't know the exact mileage on the truck as the speedo cable was shot. any help is greatly appreciated. muley
Re: loss of oil pressure
June 30, 2017, 11:17:23 am »
did you check your oil level? is it thinned out or saturated with gas?
bd
June 30, 2017, 11:41:17 am »
In addition, when was the last oil and filter change performed?
m3talc0re
July 04, 2017, 03:08:41 pm »
I'm following this because I keep losing oil pressure, too, and I'm not sure where. I changed the valve cover gaskets (they were shot), but the problem persists. Mine will cold start with good pressure, but after driving a while, then stopping at a light or something, I'll lose almost all of my oil pressure and the Choke light comes on. Plenty of oil. When I start driving again, the light will stay on, but I'll have around 20 psi on the gauge, until I stop again and it'll just bottom out.
July 04, 2017, 07:20:13 pm »
What are you running for oil?
m3talc0re
July 05, 2017, 08:59:03 am »
I'm running 5W-30
July 05, 2017, 11:34:42 am »
Run a thicker oil
Stewart G Griffin
July 08, 2017, 10:03:40 am »
Quote from: VileZambonie on July 05, 2017, 11:34:42 am
Run a thicker oil
^^^This^^^^
But also check:
1) What brand oil filter you are running.
2) Is the gauge/warning light acting up?
Trash in the pan could be a cause, but i would check 1 and 2 first.
