Author Topic: Does this look right? Power Steering Hose - 1987 Chevy 4x4 Silverado  (Read 10960 times)
Offline Mike Phillips
This picture is the inside of the inside of the fitting on the steering gear box.
Another picture...
And here's the hose end...
Re: Does this look right? Power Steering Hose - 1987 Chevy 4x4 Silverado
« Reply #1 on: July 01, 2017, 02:32:05 pm »
There is an o-ring missing on the end of the hose
« Reply #2 on: July 01, 2017, 03:38:55 pm »
I have the o-ring.
Still doesn't look like the tapers end of the hose has a place to go
« Reply #3 on: July 01, 2017, 03:56:32 pm »
o-ring makes the seal.  I just went through this with my 85
« Reply #4 on: July 01, 2017, 07:29:01 pm »
To help you get your head around it the o-ring seats (seals) in the space between the blue circles (image).
« Reply #5 on: July 02, 2017, 08:44:58 am »
Thank you.  I knew the o-ring would seat against the shoulder inside the housing.
To me, it looks like the very end of the hose fitting has no place to go?  Like it's going to be smashed into the center.
Is a portion of the  place where the hose seats int spring loaded?
« Reply #6 on: July 02, 2017, 09:04:54 am »
to me it looks like a check valve
« Reply #7 on: July 02, 2017, 10:58:43 am »
You think it depresses a little when the and of the hose butts up against it and then gets tightened down against it?
« Reply #8 on: July 02, 2017, 11:29:57 am »
i think, but not sure never really poked around with one
« Reply #9 on: July 02, 2017, 12:17:54 pm »
You're staring at the end of the flow control valve assembly.  It is the "brains" of the p/s pump, containing calibrated orifices and backed up by a spring (image).  The combination of valves and spring modulates fluid pressure and flow.  The valve statically "rests" in the closed position via spring pressure and is lifted off of its seat when the pump begins to rotate; some of the orifices serving as feedback circuits - somewhat similar to valves in an automatic transmission valve body.
« Reply #10 on: July 02, 2017, 01:50:05 pm »
Thanks BD for the picture of the spring loaded flow control valve assembly.
So to back up...
The hose I took off the truck was the wrong hose.  It was for a 1975 Jimmy and the power steering pump it was hooked to had the correct style hydraulic coupling for the 1975 Jimmy.
I'm not at the shop right now so can't take a picture of the old hose but suffice to say, the steering gear box side of the hose looks nothing like the new hose that NAPA part numbers says fits my truck.
I installed a new power steering pump with the correct hydraulic fitting for the new hose.
So it's understandable the gear box end of the new power steering hose looks different than the hose that came off of it.  While the hose that came off was the wrong hose, I don't remember it leaking at the gear box point of attachment.
So my questions and quandary is, before I install this new hose, that by all reasoning should be the correct hose for the steering gearbox, (assuming the previous owner didn't put a different steering gearbox onto this truck), I just wasn't sure if the smaller end of the hose was going to fit into the orifice on the gear box?
It looks like it's going to get mashed and smashed unless "something gives".  And it looks like with the picture BD shared shows a spring loaded component and when I install the hose, the portion of the hose I drew a green box around is going to fit in and depress the spring loaded flow control valve.
If this is so, then I'm good to go.
What I didn't want to do was take a brand new hose and install it only to find out something was wrong and it smashed the end  of the tip.
Here's pictures to show what I'm trying to explain with a keyboard....
The end of the hose with the green box around it looks like it needs to fit into a similar size opening?
Here's where the hose goes...
In this picture, the o-ring will fit into the area surrounded by the purple circles and the end of the hose shown above with the green box around it will fit DOWN into the area surrounded by the green circles and in so doing, depress this component about a quarter of an inch?
Here's the picture BD posted, note the spring...
Here I've cropped out the pertinent portion and rotated it to show how it would look in the steering gear box and when the hose is attached the portion of the hose with the green box drawn around it will touch down on the portion of the valve with the green box drawn around it.
Does the above make sense and sound right?
If so - I'll attach the hose and fire up the truck and cross my fingers all is right and there are no leaks.
« Last Edit: July 02, 2017, 01:53:05 pm by Mike Phillips »
« Reply #11 on: July 07, 2017, 06:42:33 pm »
***Update***
Attatched the power steering line - even though it doesn't look right - it tightened down and she's not leaking!
Drove the truck home last night.
« Last Edit: July 07, 2017, 06:44:20 pm by Mike Phillips »
