Author Topic: Ring and pinion swap  (Read 9233 times)
Offline burnze
« on: July 12, 2017, 05:07:09 pm »
I have an 87 r10 has a 10 bolt rear with 3.08 gears I also have a 88 k5 blazer it has 4.11 gears in the front rear end and 3.08 in the rear can I swap ring and pinions from my 87 r10 to the front rearend of the k5 blazer
83 gmc crew cab
84 chevy blazer
87 r10 short box
Re: Ring and pinion swap
« Reply #1 on: July 12, 2017, 06:04:46 pm »
Why not just swap over the whole axle assembly?
Offline burnze
« Reply #2 on: July 12, 2017, 06:26:17 pm »
Its the front rearend on a 4wd that has the gears i want to put in my 2wd
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: July 13, 2017, 05:07:11 am »
So for a little less confusion , are you wanting to take the front differential gears from a 4wd, and put them in the rear differential of a 2wd?
Gets confusing calling things a front rear. Two different locations.
 1986 Chevy K30(under repair)
Offline burnze
« Reply #4 on: July 13, 2017, 11:29:29 am »
Sorry about the confusion. Yes thats what I want to do if possible
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline Captain Swampy
  • Wisconsin
« Reply #5 on: July 14, 2017, 10:03:16 pm »
I believe he wants to swap the ring and pinion from the front  of the blazer 411s with the rear of the R10 308s. Not sure if he wants matching gears in the blazer or 411s in the R10 or both. The front axle uses reverse cut gears. They can't be swapped.
