Author Topic: Bent frame?  (Read 5379 times)
Offline Jb77c10
Bent frame?
« on: July 23, 2017, 12:13:36 am »
So my 77 c10's driver side wheel is set a good 3 inches further in than the passenger side, I know it's been in a wreck by the p.o. thing is i can't find a bend in the frame, is there a correct way to measure at home, or could it be due to suspension components, the body looks straight overall, just dog tracks, any advice would be appreciated
Sent from my SM-J700T1 using Tapatalk
One man's trash is another man's treasure
Offline roundhouse
Re: Bent frame?
« Reply #1 on: July 25, 2017, 06:44:05 am »
Could just be the body mounts
I'd take it to a auto body or frame shop that has some grey haired guys working there
Re: Bent frame?
« Reply #2 on: July 25, 2017, 08:05:50 am »
Have you tried loosening all of the body mounts and shifting the cab? Are the body mounts good? You can check the frame squareness using a tram gauge. You can make your own tram gauge as well if you suspect the frame is the issue.
Offline Jb77c10
Re: Bent frame?
« Reply #3 on: July 25, 2017, 12:43:14 pm »
Right, that's my plan it just bugs the crap out of me, short on cash at the moment to have it looked at, I will inspect the body mounts
Re: Bent frame?
« Reply #4 on: July 26, 2017, 07:42:50 am »
keep in mind 3" difference is only 1.5" off (split between the two sides). but look at your bumper also, the gap on the sides between the bumper and fender.
Offline Jb77c10
Re: Bent frame?
« Reply #5 on: July 29, 2017, 01:14:42 am »
I will definitely check that out
