Author Topic: Oil pressure sensor help  (Read 5329 times)
Offline SicC10
« on: August 30, 2017, 05:29:18 pm »
Ok I just bought a 85 gmc with 305. Don't think it's the factory motor. Anyway I have this sensor in the back on manifold that I just replaced with single wire connector. Do these trucks have a sensor for a oil pressure light the. Another for the gauge? Or is it one or the other?
Re: Oil pressure sensor help
« Reply #1 on: August 30, 2017, 05:52:41 pm »
Are you saying the one you have looks like the one pictured? Do you have a gauge or idiot light?
Oil pressure sending unit is for the gauge, oil pressure switch is for the electric choke.
Offline SicC10
« Reply #2 on: August 30, 2017, 10:41:48 pm »
I have a gauge but doesn't seem to work. It's pegged to the far right past 60. So where is the sensor for the gauge located? I've only found the one I pictured and it's on the rear of the intake next to the distributor.
Offline Rattler12
  • Old Geezer
« Reply #3 on: August 31, 2017, 08:25:08 am »
The one in the picture is just an "on-off" type switch used in vehicles with idiot lights. The sender for a gauge set up is entirely different. Both can be mounted in the block next to the distributor or can also be mounted in the block right above the oil filter. I had to use a 45 degree bend for the gauge sender in my 350 37 pu to angle it away from the block to keep from hitting the HEI dist.
83 C-10 shorty 454, 5spd, 3:73 posi
Offline Spoonbill
« Reply #4 on: August 31, 2017, 06:01:00 pm »
I have an 87 r10 305tbi 700r4 and I have the same issue. One day the gauge worked and then it just pegged past 60. I found the same part you did and replaced it and nothing so exactly where do we need to look and what color will the wire be?
Offline Spoonbill
« Reply #5 on: August 31, 2017, 06:09:28 pm »
I have a similar looking sensor in the block right between 1 and 3 spark plugs
« Reply #6 on: August 31, 2017, 06:19:56 pm »
That's the cylinder head not the cylinder block and is the coolant temperature sending unit.
Oil pressure sending unit - for the gauge has a fat body. Oil pressure switch has two terminals and for tbi systems is used as a backup for the fuel pump relay.
