Body, Glass & Paint
buffing single stage urethane
Topic: buffing single stage urethane (Read 4826 times)
kcwis
September 04, 2017, 04:19:30 pm »
What kind of buffing wheel,pads do I need to buff,I have wet sanded it smooth but now it's dull, 1976 gmc 1/2 ton long bed.Can I use a d/a?with the proper pads.
Re: buffing single stage urethane
September 04, 2017, 05:37:50 pm »
You need a variable speed buffer, foam pad and polishing compound.
JBlanks
October 16, 2017, 09:41:25 pm »
What grit sand paper did you wet sand with last?
JBlanks
October 16, 2017, 09:44:13 pm »
And you can go to your local automotive paint store and get the pads and buffing compounds you need.
October 17, 2017, 07:23:01 pm »
Harbor Freight carries those supplies now, much cheaper than the regular stores if you have one around anyway.
Body, Glass & Paint
