Author Topic: selector valve 87 chevy truck  (Read 8331 times)
Offline KAY KAY
« on: September 13, 2017, 12:35:11 pm »
Does anyone have a video on how to install a gas selector valve for a 87 chevy pick up truck?
Re: selector valve 87 chevy truck
« Reply #1 on: September 13, 2017, 04:20:48 pm »
does it have one already? it should be a simple swap. are you sure its your issue and not the switch in the dash?
Offline jetman
    • Squarebody Referance Library
« Reply #2 on: September 13, 2017, 07:02:18 pm »
Getting to it from below is a pita.
I am thinking about changing my own out.  When I do I will pull the  SWB bed, change  the selector valve out and also change out all the 34 year old, pre- Ethanol era,  OEM rubber hoses going to my old rusty tanks.
Offline ehjorten
« Reply #3 on: September 14, 2017, 08:34:23 am »
It is 2 bolts, 1 electrical connector, and 6 hose connections.  You have to remove the heat shields first to get to it.  It isn't really that difficult to get to from under the truck.  Easier if you truck is lifted.
-Erik-
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: September 14, 2017, 09:08:12 am »
The selector valve is normally mounted under the cab, so removing bed and doing from top won't work.
 1986 Chevy K30(under repair)
Offline jetman
« Reply #5 on: September 15, 2017, 09:23:10 am »
1987 Squarebody selector valves were only installed on the cross-member under the bed.  GM never mounted them under the cab.
« Last Edit: September 15, 2017, 09:25:40 am by jetman »
« Reply #6 on: September 15, 2017, 01:15:05 pm »
I keep forgetting in 87 they changed to TBI.
Offline jetman
« Reply #7 on: September 15, 2017, 01:23:45 pm »
Yep, GM went to TBI in '87.  But yes, you are probably still correct, I believe the selector valve is actually under the cab.
My '83 truck has an ongoing issue with the fuel delivery system; tanks, selector and rubber fuel lines all very suspect.  Need to change 'em when I find the time and am willing to put up w/ the dust/dirt and fuel dripping down my arms and face.
« Reply #8 on: September 15, 2017, 03:00:32 pm »
i want to say on my 91 the valve is in the triangle of the crossmember right at the head of the bed
Offline AZ4X4SQBDY
« Reply #9 on: September 15, 2017, 08:46:06 pm »
My TBI '87 GMC 4x4, short fleet side bed has it mounted under the cab in the same place as my '85. The hose clamps were different on the valve end and the other end of the hoses had a crimp on fitting to retain it. It required the same valve as the '85 also.
Loosening the cab mounting bolts and lifting the cab with a jack helped some of the hoses on and the clamps tightened.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
« Reply #10 on: September 16, 2017, 08:13:35 am »
The bolts are on top of the frame rail. Soak them with some penetrating oil and then break them loose with a box end wrench. Once they are free you can spin them out with an open end or stubby wrench. Remove the fuel line clamps in close proximity to give you flexibility and pay close attention not to mis match hoses. Take pictures or label accordingly for reference. Replace sections of hose and clamps while you are in there and make sure you don't kink any when you reinstall. It's a good idea to loosen the gas gaps during the procedure as well. Have a catch pan to collect the fuel loss. Wear proper PPE, no incandescent drop lights etc. See images in link below
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9072.0
