Engine/Drivetrain
Vacuum line abatement question/questions
Topic: Vacuum line abatement question/questions (Read 4826 times)
BobBastion
September 15, 2017, 04:10:22 pm »
I recently acquired an 82 Silverado. The intake is scarcely visible due to the insane amount of vacuum lines
. I have replaced a lot of the lines that were dry rotted. My questions are: Are all these lines absolutely necessary? If not, What can I get rid of? If there is another thread or resource that addresses this please direct me. I couldn't find anything, hence the post. It runs good presently so I'm in no hurry. I'm just doing research for the future. Thanks. -Bob
Re: Vacuum line abatement question/questions
September 15, 2017, 06:23:22 pm »
First
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5220.0
Second, are they necessary?Wwell yes, if they are being used to operate a functional circuit.
The question is what are you trying to accomplish? Are you in a non-emission state and looking to simplify things, clean up the engine compartment, explain what you are going for. Give details on your setup. Post pics.
BobBastion
September 15, 2017, 11:19:29 pm »
Yes, my aim is to clean up the engine compartment and simplify. Maybe put an aftermarket breather on it. Thankfully, there is no smog pump. Surely I am not the only one that has looked at that tangle of tubes and thought: "that's got to go."
Pics are forthcoming. Standby.
Stewart G Griffin
September 17, 2017, 11:47:28 am »
i've removed everything, including EGR, and only have pcv, and a hose going to vacuum on the distributor. Truck runs well.
The truck DID NOT originally come with a smog pump, but the engine i am using now did. (v-8 vs. v-6) So, i've also removed the A.I.R. lines going to the new exhaust manifolds and plugged those as well.
i don't have time now to post pics----photobucket decided not to do business the right way. So, i will attempt to repost those in a few weeks. In the meantime, you might trying searching under my posts for some more recent pics which show the new engine in a very un-complicated setting.
Stewart G Griffin
September 17, 2017, 12:10:23 pm »
Before:
After:
Also, before i switched to the 6, i did run a 305 for a while with a much simpler layout, but i really don't have time to post pics of that now.
September 17, 2017, 06:49:56 pm »
Stewart, why the rinky dink air cleaner?
Stewart G Griffin
September 17, 2017, 09:02:15 pm »
Quote from: VileZambonie on September 17, 2017, 06:49:56 pm
i know, i know----this is just temporary---because i needed the truck running ASAP. i plan on getting a K+N after this one plugs----which shouldn't be too much longer.....
Also, the stock v-8 air cleaner housing will not fit----because the carb is further back on the v-6. i don't have a v-6 housing.
2) Because of this, i will most likely only be able to go with a 9" diameter air cleaner.
Engine/Drivetrain
