Author Topic: fan shroud  (Read 12554 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
fan shroud
« on: September 17, 2017, 04:36:26 pm »
I have a 1986 custom deluxe 4.3 L vortec 2wd Automatic w/o air . The fan shroud needs to be replaced. I ordered one through summit racing   part number is gm3110101. When it came it was the wrong one  >:( Ive looked all over the web and everyone tries to sell me this same shroud. the gm 3110101 is not wide enough. As in from the radiator to where it goes over top the fan is not wide enough. please any ideas will be greatly appreciated i have looked for months with no luck. Cant find it in local junk yards either.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Offline Henry
Re: fan shroud
« Reply #1 on: September 18, 2017, 12:21:28 pm »
Hi Smitty:
Is your fan shroud a one-piece or two-piece design? Can you elaborate a little more on where the fit problems is? Does this shroud you bought look like the original one but just not have the right dimensions? Is it a two-piece design?
Maybe you can contact a Chevy dealer who has the older parts catalogs and can tell you if there was more than one design for your model truck.
*My old 76 350 fan shroud attachment screw holes were starting to break up and there was a couple of cracks and so I tried to order the right one but got the wrong one as well. Instead of repeating this hassle of returning parts I decided to repair it myself with 3M #2216 structural adhesive. Problem solved.
Good Luck,
Henry
Offline Stewart G Griffin
Re: fan shroud
« Reply #2 on: September 18, 2017, 02:16:22 pm »
i'm guess that it's too short----won't reach the fan----because the v-6 sits so much further than the 8.
i had the same problem and decided to go with an electric fan.  Problem solved, much more room.  Haven't looked back.
Offline Smitty31
Re: fan shroud
« Reply #3 on: September 18, 2017, 04:36:09 pm »
It is a two piece and thats exactly right the  new shroud wont go over the fan plus the shape is a little different. as in repairing it that wont work to many missing pieces. i will check with a chevy dealer. but welcome more comments.
Re: fan shroud
« Reply #4 on: September 18, 2017, 08:17:52 pm »
I got one free in NW Indiana if you can pick it up, came out of my 86
Offline Smitty31
Re: fan shroud
« Reply #5 on: September 19, 2017, 10:20:01 am »
I would be glad to pay you for it and shipping along with your time.
Offline Smitty31
Re: fan shroud
« Reply #6 on: September 19, 2017, 10:22:39 am »
Also looking for a set of headers have stock manifold now. I believe it would really help my duals and performance
Offline Smitty31
Re: fan shroud
« Reply #7 on: September 21, 2017, 06:07:42 pm »
ok i have a 1986 custom deluxe A.T. 2wd 4bb 4.3 Liter w/o air . my fan shroud is unrepairable. the orginal shroud part # 15522749 it has been discontinued. I have search the internet using that part number with no luck. I live in knoxville Tn. if anyone has one for sale or has any ideas on how to find one your help would be greatly appreciated. i have had no luck at junk yards either. thanks Smitty31
Re: fan shroud
« Reply #8 on: September 21, 2017, 06:20:15 pm »
Where did you get that part number? You should have a two piece fan shroud.
Offline Smitty31
Re: fan shroud
« Reply #9 on: September 21, 2017, 07:11:36 pm »
 After many many  hours  looking off and on for months on the internet I have located the fan shroud its even a original GM part.  I found it at  Northeast GM parts $80.70 .  Here is the part numbers for anyone else who may need Done. upper shroud 15522748  lower 15522749 .   ;D
Offline Smitty31
Re: fan shroud
« Reply #10 on: September 21, 2017, 07:17:14 pm »
Vile zambonie thats was just the lower half part number. i included both part numbers in above post thanks.
Offline Smitty31
Re: fan shroud
« Reply #11 on: September 21, 2017, 07:18:22 pm »
Remember if its worth doing its worth doing right !
Offline Smitty31
Re: fan shroud
« Reply #12 on: September 21, 2017, 07:20:41 pm »
please disregard last post i was trying to figure out how to add quotes to my messages
Offline Smitty31
Re: fan shroud
« Reply #13 on: September 28, 2017, 04:39:56 pm »
well back to square one. After a week GM notifies me the my fan shroud is discontinued. Something i already new. Any help from anyone would be great.
Re: fan shroud
« Reply #14 on: September 28, 2017, 06:08:04 pm »
are you looking for the top or bottom or both? Post pics of the one you have.
