Author Topic: steering gear box  (Read 5660 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
steering gear box
« on: September 23, 2017, 07:01:41 pm »
1986 custom deluxe 4.3 L 4 BBL w/o air 400 trans w/o cruze. On the top of my steering gear box there is a plug for a electrical connection. But there is no wires running to it. My best guess is its a sending unit for something. But what i dont know. p.s. and yes its a  powering steering truck.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Offline Smitty31
Re: steering gear box
« Reply #1 on: September 24, 2017, 11:45:33 am »
Here is a pic of it. I was mistaken the sending unit or whatever it is. Is actually in the powering steering line right before it goes into the steering gear box.
Offline AZ4X4SQBDY
« Reply #2 on: September 24, 2017, 11:58:48 am »
Does it have a idle speed compensator on the side of the throttle linkage?
A guess would be it that it would tell the ECU to bump the throttle up when the steering box is in a bind or near relief pressure.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
Offline Smitty31
« Reply #3 on: September 24, 2017, 12:05:23 pm »
No but there are two screw that look likes maybe something was there before. thanks for your input.
« Reply #4 on: September 24, 2017, 01:25:40 pm »
Should be a brown and black wire connector. The black wire connects to the frame. Is your ECM in tact?
Offline Smitty31
« Reply #5 on: September 24, 2017, 03:39:56 pm »
yes ecm is intact but cant find the wiring.
Offline chevn-up
« Reply #6 on: September 30, 2017, 05:33:52 am »
could be the brake pressure sender. I know GM built them into the proportioning valve to a warning light in the dash cluster.
Offline chevn-up
« Reply #7 on: September 30, 2017, 05:36:35 am »
uh oh, dummy me, I was looking at the wrong thing. sorry.
