Author Topic: Engine almost dies when putting in gear  (Read 6020 times)
Offline Spoonbill
« on: September 25, 2017, 02:28:15 pm »
Hey guys, me again. 87 r10 305 tbi 700r4. Truck is off, I start it up doesn't matter if I shift into drive or reverse, it will almost die. It stumbles until it catches itself. It doesn't matter if it is warmed up or not. Anyone have a clue as too what might be going on? Started doing this about 3 weeks ago and just getting worse
Re: Engine almost dies when putting in gear
« Reply #1 on: September 25, 2017, 03:11:55 pm »
Is the service engine soon (SES) light illuminating when the symptoms occur?  Last month you were going to have the ECM scanned for trouble codes.  Did you?  What codes were stored?
« Reply #2 on: September 25, 2017, 05:40:10 pm »
and spray carb clean at the base of the TBI to see if it changes engine speed.
Offline Spoonbill
« Reply #3 on: September 25, 2017, 07:47:11 pm »
Had it scanned and no fault codes. Just replaced the tbi base gasket. No warning light is on except when you first turn the ignition.
Offline Captain Swampy
  • Wisconsin
« Reply #4 on: September 25, 2017, 09:21:20 pm »
The body of the TBI could be worn at the throttle shaft and leaking air though. Possibly EGR valve also.
Offline Spoonbill
« Reply #5 on: September 26, 2017, 03:13:41 pm »
Can't I just take the egr off??? Sprayed and no change in idle
« Reply #6 on: September 26, 2017, 05:15:26 pm »
Pull the vacuum hose off of the EGR valve and plug it. See if the symptoms go away.
Offline burnze
« Reply #7 on: September 26, 2017, 06:42:19 pm »
Have you checked fuel pressure?
83 gmc crew cab
84 chevy blazer
87 r10 short box
Offline Spoonbill
« Reply #8 on: September 27, 2017, 08:15:47 am »
Haven't checked fuel pressure. What is the easiest way to check it?
Offline Spoonbill
« Reply #9 on: September 28, 2017, 01:50:36 pm »
Anyone have an idea on this? It is acting like manual when the clutch isn't releasing all the way. All I need is a direction to head but I have never heard of this. Thanks
