Author Topic: Gen 1 intake manifold to Gen II block  (Read 4941 times)
Offline Surfdude
« on: September 28, 2017, 12:08:56 pm »
I know there are lots with more experience than me and a few of you who also have to contend with the lovely CARB regulations here in California so..
1978 Chevy C10
Engine 350 SBC
Intake manifold with all of the state-mandated smog fittings casting number: 346249
The new block has a casting number of 10243880, 92-96 model years.
Will the two mate unmodified?  I ask because as I am trying to put the manifold on but the 4 center bolts look as if they are drilled at a more perpendicular (straight up) angle than the rest.  I am asking before I get the grinder out and modify the holes then epoxy back to size.
I would like to put an aftermarket intake manifold on, but there are no intake manifolds with the magic EO (executive order) paperwork available.  Has anyone put on a Performer manifold with the EGR option and successfully passed smog in CA?
I want to keep it carb'ed  (I luvs me the sound of 2ndaries opening up) so am leaning against TBI, that and the hassle of the state come smog time.
I appreciate all of the help, I would post pictures if I was doing anything interesting but all of us have seen greasy engines that have sat for 30+ years.
Thanks for the help,
1978 Chevy C10 Stepside
"Strange things are afoot at the Circle K"
Re: Gen 1 intake manifold to Gen II block
« Reply #1 on: September 28, 2017, 06:44:25 pm »
It's not the block it's the cylinder heads that you have to worry about. If you are putting an early manifold on center bolt heads then you need to elongate the 4 center bolt holes. I'm fairly certain professional products intakes come with the adapters and elongated holes.
Offline Rattler12
  • Old Geezer
« Reply #2 on: September 29, 2017, 08:35:55 am »
They do. I have one on an 87 350 in my 37
83 C-10 shorty 454, 5spd, 3:73 posi
Offline Surfdude
« Reply #3 on: September 29, 2017, 07:06:34 pm »
Thanks, I have not contacted Professional Products.  Let's see if they have a CARB-certified intake manifold. ( I think this is a unicorn)
This is what I get for 'knowing' without verifying.  I just knew the cutoff for smog was the model year when they went to TBI when I bought this. ::)  Bah.
Well, Just have to get on with it.   Worse case I will tap the existing holes in the manifold, fill with a low grade bolt, and re-drill at a more correct angle.
I think I can figure out something for a boss for the bolt side and braze it on afterwards.
If only I 'knew' (there is that word again) that IF I bought an aftermarket manifold with an EGR that all would be OK with the smog police.  I personally don't see why not but  I ran into a similar situation a few years back with a cracked intake manifold and the referee would not budge.  OEM, junk it, or TBI were my options.
 Again, thanks for the help here. If Professional Products doesn't have what I can use, I will post the ensuing photos for the collective hilarity and head-shaking of the general community.
« Reply #4 on: September 30, 2017, 06:26:22 am »
Drilling out the 4 center bolt holes in the intake is a simple and easy solution. You can make angled bushings yourself as well.
« Reply #5 on: September 30, 2017, 06:28:56 am »
