Author Topic: weather stripping  (Read 4676 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
weather stripping
« on: October 15, 2017, 01:31:30 pm »
I have a 1986 custom deluxe and have replaced all the weather stripping around the doors and the felt around the door glass. I have adjusted the doors and the door hinges are in good shape. But still when driving down the road you can hear air like its trying to come in but really cant feel it. Anyone else have this problem? Also i noticed my 1979 has a piece of weather stripping on  top of the door above glass but my 1986 does not.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Re: weather stripping
« Reply #1 on: October 15, 2017, 01:55:42 pm »
Check your wing windows.  Fold a business card a couple of times and close the latch on it.
Offline Smitty31
« Reply #2 on: October 15, 2017, 02:04:48 pm »
Thanks for the suggestion but i have already done that with a couple of washers.
« Reply #3 on: October 15, 2017, 06:47:00 pm »
Put electrical tape around the vent window. If the noise goes away then you found your leak.
Offline Smitty31
« Reply #4 on: October 16, 2017, 04:38:13 pm »
I will give it a try.
Offline Smitty31
« Reply #5 on: October 19, 2017, 05:42:49 am »
Did the electrical tape around wing windows. It didn't help
« Reply #6 on: October 19, 2017, 05:02:20 pm »
Well then you know your leak is not from the vent windows. Use a mechanics stethoscope to pinpoint the leak
