Author Topic: Steering wheel lock?  (Read 12506 times)
Offline DanMcG
« on: November 02, 2017, 02:56:47 am »
I got a 77 k10 that was a standard trans on the floor. The wheel doesn't lock when the key is off. Should it?
Re: Steering wheel lock?
« Reply #1 on: November 02, 2017, 02:53:51 pm »
Yes
« Reply #2 on: November 04, 2017, 07:10:36 am »
the lock also acts as a spacer for the steering wheel and column. without it the wheel with have play on its axis. but you can disable the locking pin with glue or it might be able to become all gummed up and get stuck in the "released" position
« Last Edit: November 04, 2017, 07:42:32 am by Irish_Alley »
Offline blazer74
« Reply #3 on: November 05, 2017, 11:24:20 am »
Coincidence on this post. Replaced my ignition switch on top of my column.
Was all good, now can’t turn the key to auxiliary and the steering wheel lock and park lever lock does not work.
Off comes the steering wheel and see what I broke.
I dislike creating my own problems.
Offline roundhouse
« Reply #4 on: November 06, 2017, 07:29:39 am »
The little rack and pinion thing is probably off a tooth or two
Also the electric switches at the bottom of the Collumn have a slotted mount so they can be adjusted a little
Offline blazer74
« Reply #5 on: November 06, 2017, 09:57:02 am »
  Thanks for the input, I’m sure something is amiss in the rack and sector.
Starts fine.
Jamming when going to aux, other than that fine.
It was working fine after replacing and adjusting the ignition switch.
After it was back together it worked, jammed then worked then jammed again.
Took a quick look and apparently 73-77 has a different rack and gear sector that not as available as the later years.
Offline roundhouse
« Reply #6 on: November 08, 2017, 09:29:18 am »
Some years switches pulled the remote control rod down the column and some years pushed the rod
They all look alike but GM made quite a few changes
The same switch at the bottom is used , you just flip it backwards to use on the push or pull
« Reply #7 on: November 08, 2017, 12:44:52 pm »
Yes sounds like it is out of position so the spring bolt isn't fully engaging the lock plate
Offline blazer74
« Reply #8 on: November 08, 2017, 02:58:12 pm »
Going to try and get back to mine this weekend and see what’s up.
