Author Topic: Does anyone know what this sound is?  (Read 6043 times)
Offline audrima
« on: November 11, 2017, 04:08:35 pm »
hello all,
My truck( 1978 GMC C25 hd with a 350 Qjet) is making a weird noise. and I don't know what it is. I'm thinking rocker is lose.
here is 2 clips  to hear it.
https://www.dropbox.com/s/xs7orold7qkxb7j/20171111_155044.mp4?dl=0
https://www.dropbox.com/s/92ynbs1q09b7y4o/20171014_122947.mp4?dl=0
don't know and I need to drive her to nyc very soon and tow a Subaru home.
any home will be welcome thanks!
Aud
« Last Edit: November 11, 2017, 04:21:29 pm by audrima »
Re: Does anyone know what this sound is?
« Reply #1 on: November 11, 2017, 04:59:28 pm »
Did you check the oil?
Offline audrima
« Reply #2 on: November 11, 2017, 05:06:09 pm »
oil is full of 10w40 (though it is 2 years old but only 800 miles.)
Aud
« Reply #3 on: November 11, 2017, 05:09:13 pm »
I hear an exhaust leak, loose alternator belt and a noisy lifter
« Reply #4 on: November 11, 2017, 05:11:21 pm »
Does it have an oil pressure gauge? Does it read pressure? If so, pull the valve cover, make sure oil is coming to the rockers, check valve adjustment. What kind of oil have you been using?
Offline audrima
« Reply #5 on: November 11, 2017, 05:20:13 pm »
there is a exhaust leak, but its taped up, sooo need a new y pipe.  I'll check the belts I did just change the water pump. I hope it's something easy like a lifter!  The oil when I first start is at 60 but after it warms up (or about 20 min) is goes and stays at 40 (in the middle). i it has pensoil 10w40 right now. about 800 miles since it was change...2 years ago (almost 3) this truck has had pensoil all it's life.
thank you for your replies.
Offline FlatBlack77
« Reply #6 on: November 11, 2017, 05:57:11 pm »
I wouldnt call replacing a lifter an easy job. not extremely difficult but its not just a few bolts kinda job.
I would pull the valve cover like Vile said. might aswell do both. make sure everything is getting oiled and youll probably be able to find the loose one very easily
Offline audrima
« Reply #7 on: November 11, 2017, 06:05:26 pm »
Well easy compared to replacing the whole engine. valve covers come off tomorrow (if there is money in the bank lol)
thanks everyone
Aud
Offline Engineer
« Reply #8 on: November 11, 2017, 06:36:43 pm »
Give each of your rocker nuts a 1/4 turn and see if that quiets the lifter.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline audrima
« Reply #9 on: November 11, 2017, 07:17:14 pm »
I will do that thank you
aud
