Author Topic: Ac blend door actuator knocking  (Read 7824 times)
Offline jptiger
  • Husband of Kim father of Joshua
« on: November 28, 2017, 10:58:31 am »
On passenger side under glove box. Which acuator is this? This is on 92 GMC Sierra k1500. Thank you happy holidays
1977 GMC Sierra Grande K15 swb
1992 GMC Sierra K1500 ext cab
Re: Ac blend door actuator knocking
« Reply #1 on: November 28, 2017, 06:26:11 pm »
Does it only do it when it reaches its final position? When you change it does it stop?
It's most likely the actuator motor is broken but you need to remove it to check it. See the attached pic.
PS - non 73-87(91) vehicle questions go in General Discussion which is why it was moved.
Offline jptiger
« Reply #2 on: November 30, 2017, 11:04:07 am »
Thank you this is big help
Offline jptiger
« Reply #3 on: November 30, 2017, 11:06:18 am »
When I go from defrost to floor it knocks. Go from floor to defrost it stops.
« Reply #4 on: November 30, 2017, 04:28:14 pm »
That's mode not blend
« Reply #5 on: December 01, 2017, 10:04:42 am »
my 94 will do this sometimes. almost like the motor itself shuts the door then the last inch it just slams it just once. or does it click multiple times?
Offline jptiger
« Reply #6 on: December 04, 2017, 09:23:28 pm »
Multiple times. Rick/flap sound. About 20 times then it stops. Driving me nuts
Offline jptiger
« Reply #7 on: December 04, 2017, 09:23:56 pm »
Excuse me. Tick/ flap sound.
Offline jptiger
« Reply #8 on: December 04, 2017, 09:26:01 pm »
I know this is a 92 and I apologize I just needed some help. Thanks
« Reply #9 on: December 05, 2017, 06:04:08 pm »
The image shows you where the mode door actuator is. What other help are you looking for?
« Reply #10 on: December 06, 2017, 06:26:03 pm »
im with vile. sounds like the actuator broken. i picked one up from the junkyard years ago to replace mine and its still going.
