Author Topic: Idle jets plugging on edelbrock carb 1406 model  (Read 10819 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: November 30, 2017, 06:20:26 pm »
So I have a 1974 chevy half ton stepside.  (C10).  Has a 350 with an edelbrock carb, I think the model is a 1406 carb.  The idle jets are repeatedly plugging up.  I open the jets by removing the needle valves and spraying with carb cleaner then compressed air.  I replace the needle valves and readjust and everything is fine for a bit then I have to do it again.  Sometimes 50 or a hundred miles and sometimes a few hundred miles.  I thought maybe the gas line was coming apart so I replaced it all and replaced all 3 filters in the line, but I am still seeing the idle jets plug.  (Symptoms...I get a rough idle, and find that one of the needle valves has no effect on the idle when I screw it in or unscrew it).  Anybody seeing this or have any ideas?  This problem is so common that edelbrock has a youtube on it.  I may need to switch carburetors
to a more trouble free model.  Any suggestions??
Ricky
Re: Idle jets plugging on edelbrock carb 1406 model
« Reply #1 on: November 30, 2017, 08:53:27 pm »
Very common especially if there's junk in the tank or bad gas. Where and what kind of fuel filter are you running?
Offline fiddler
« Reply #2 on: December 02, 2017, 11:32:52 pm »
I have a filter at the input to the fuel pump and two filters afterwards.  The filters on the output are the standard glass filters with replaceable mesh filter.  I don't have the packaging so I don't remember the brand names.  Is there a "best" fuel filter?  I would gladly install one if I heard there was one out there.
Thanks much for your help.
(So the redundant filters were already in the truck when I replaced the gas line.  I just went with what I had and replaced everything rather than re design.  Maybe better to get one real good filter at the output of the fuel pump.)
ricky
Ricky
Offline fiddler
« Reply #3 on: December 03, 2017, 12:17:51 am »
So this is the fuel filter being used in the truck.
« Last Edit: December 03, 2017, 07:22:13 am by VileZambonie »
Ricky
« Reply #4 on: December 03, 2017, 07:23:38 am »
So you have 3 of those?
I would throw those in the trash, you only need one filter and I would put it in after the pump before the carburetor.
Offline fiddler
« Reply #5 on: December 03, 2017, 03:38:00 pm »
Any suggestions as to what type of filter I should purchase?  If these aren't doing the job I hate to buy another that doesn't do the job.....
thanks for any advice,
ricky
Ricky
« Reply #6 on: December 04, 2017, 02:38:57 pm »
Any universal quality 3/8" filter will do the trick. A lot of guys prefer the transparent filters but any parts store will have them in stock. Put it in a place where you can easily service it and where it is away from danger.
Offline roundhouse
« Reply #7 on: December 07, 2017, 04:54:53 am »
You might wind up with a new tank
I've had a couple of older vehicles where the filter would clog every 25-50 miles and I had to replace the tank
It had so much rust and dirt in it
I used the clear plastic 3/8 filters so I could see what it was catching
A new tank from rock auto is less than$100
Offline Engineer
« Reply #8 on: December 08, 2017, 02:14:06 pm »
My son had a ‘79 GMC that we ended up replacing the tanks on. 50 miles to the fuel filter was a pain.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline fiddler
« Reply #9 on: January 08, 2018, 11:28:22 am »
Thanks All.  I seem to have cleared the problem with new gas lines and filters.  Maybe I got a tank of bad gas??  It has been over a month now with no plugged idle jets.
Ricky
Offline Willy Lee
  • Lol
« Reply #10 on: January 08, 2018, 10:15:55 pm »
very common when you put junk on your intake manifold.
Offline Willy Lee
  • Lol
« Reply #11 on: January 08, 2018, 10:26:13 pm »
ricky
not one of those clear pieces of crap, unless you like engine fires.
Offline Big Chip
« Reply #12 on: January 08, 2018, 10:27:19 pm »
Are you say edelbrock carbs are junky?  I've heard that they were pretty good. Does Carter still make carburetors?  Those are good, right?
Offline Willy Lee
  • Lol
« Reply #13 on: January 08, 2018, 10:40:42 pm »
Meh I found the best way to tune an Edelturd is with a 3lb sledge. I guess if you like low performance and mediocre drivability then I guess they are ok. It’s a shame that the Weber logo is on them kinda cheapens that brand a bit.
Offline Big Chip
« Reply #14 on: January 08, 2018, 10:43:08 pm »
That's good to know. It sounds like you really know about carburetors.
