Members Rides
project onion rings
4
14
Topic: project onion rings (Read 224484 times)
JohnnyPopper
Old Goof
Re: project onion rings
Reply #15 on:
January 02, 2019, 01:42:10 pm »
Nice work man!
I'm digging into a 1980 C-10 right now, I like what you did with the LED's.
Why did you remove the AC? Do you live in Cold Country?
1980 C-10 under construction
chevn-up
Reply #16 on:
January 18, 2019, 12:48:52 pm »
Original 305, rebuilt. mild cam.
chevn-up
Reply #17 on:
January 18, 2019, 07:20:02 pm »
Got the rear disc's plumbed.
chevn-up
Reply #18 on:
January 18, 2019, 07:49:40 pm »
another
chevn-up
Reply #19 on:
March 31, 2019, 02:03:11 pm »
Been busy upgrading my tunes. This will help.
chevn-up
Reply #20 on:
March 31, 2019, 02:11:45 pm »
Big day when the engine is back between the frame rails.
chevn-up
Reply #21 on:
April 14, 2019, 06:49:08 pm »
Some scrap wood, a little ingenuity, and Bam! the front porch is now a cooler place to hang-out.
chevn-up
Reply #22 on:
May 11, 2019, 06:41:14 am »
Got my new shoes today. Been eyeing these for some time to go on sale. Staggered set, 275/40/20 245/40/20. My wheels of choice are a different story. Everyone I have checked with are out of stock. The last guy I talked with called the manufacturer directly and they told him the wheels are 90 days out. That's cool. Meanwhile, the house smells like a rubber factory.........That's cool too.
chevn-up
Reply #23 on:
June 06, 2019, 08:06:02 pm »
Time for new gear oil for the diff.
chevn-up
Reply #24 on:
June 06, 2019, 08:11:05 pm »
The oil-fill plug on my differential is seized up. I heated it up, and even used a hammer and punch, without any luck. So, I opted to get a cover with the "oil fill plug".
chevn-up
Reply #25 on:
June 06, 2019, 08:16:21 pm »
There are lots of covers on the market advertised as having the "oil drain" plug. Be careful selecting which one you purchase. This pic is the factory cover showing the original oil line in the diff.
chevn-up
Reply #26 on:
June 06, 2019, 08:19:14 pm »
I used a straight piece of metal rod to show the cover advertised as an "oil fill" plug. You can see this cover will allow me to fill the diff.
Last Edit: June 06, 2019, 09:11:44 pm by chevn-up
heavychevy91
'86 Chevy K20
Reply #27 on:
June 17, 2019, 07:15:35 pm »
Nice work! I like your attention to detail. When I saw those perfectly bent brakes lines I knew. Also liked the Lennon quote, have the same thing tattooed on my ribcage. Keep up the good work
chevn-up
Reply #28 on:
June 23, 2019, 05:37:40 pm »
Got the shifter re-installed.
chevn-up
Reply #29 on:
June 23, 2019, 05:41:01 pm »
Also replaced the dime-store battery disconnect that was in the truck with this unit.
4
14
Members Rides
project onion rings
