Author Topic: project onion rings  (Read 300021 times)
Offline Shifty
  • I bleed Bowtie red...
Re: project onion rings
« Reply #90 on: March 28, 2020, 10:34:03 am »
I love that tank relocate/filler door!  8)
98 C2500 ext cab longbed
Offline Mike81K10
« Reply #91 on: March 28, 2020, 11:18:38 am »
Very nice work and your attention to detail very evident. Wish I had your talent! Its going to be a great ride when your done.
Offline chevn-up
« Reply #92 on: March 28, 2020, 09:38:41 pm »
Thanks all. The tank mod was like the #1 thing I wanted to do.
Offline chevn-up
« Reply #93 on: April 19, 2020, 03:42:36 pm »
Here's one for ya. The balance weights on one of my wheels just fell off the rim. Double-sided sticky tape is what is used now.
Offline chevn-up
« Reply #94 on: April 19, 2020, 03:43:56 pm »
After re-balance these are the weights. (same wheel)
Offline chevn-up
« Reply #95 on: April 19, 2020, 03:58:54 pm »
Now I am no expert, nor have I ever operated a wheel balancing machine, but WTH? So for piece of mind, I will take all four wheels to a third party tire shop and re-balance the lot.
Offline chevn-up
« Reply #96 on: April 19, 2020, 05:24:18 pm »
Back to the build, filled-in the stake pockets on the bed. Easier to buy 'em than make.
« Last Edit: June 18, 2020, 07:39:30 am by bd »
Offline chevn-up
« Reply #97 on: April 19, 2020, 05:25:36 pm »
again..
Offline chevn-up
« Reply #98 on: April 19, 2020, 05:27:11 pm »
Just makes sense to me to remove the front pockets.
Offline chevn-up
« Reply #99 on: April 19, 2020, 05:28:37 pm »
I like this look better.
Offline JohnnyPopper
  • Old Goof
« Reply #100 on: April 19, 2020, 08:03:07 pm »
Are you using a bubble balancing machine?
If yes, there is a method of getting the best result. LMK
1980 C-10 under construction
Offline chevn-up
« Reply #101 on: August 25, 2020, 05:32:56 pm »
Here are the last of my re-sizing old pics. To get the louvers punched, I first removed the inner panel of the hood. A reciprocating saw worked to cut the glue.
« Last Edit: August 11, 2026, 06:01:20 pm by chevn-up »
Offline chevn-up
« Reply #102 on: August 25, 2020, 05:34:03 pm »
yes sir.
Offline chevn-up
« Reply #103 on: August 25, 2020, 05:40:49 pm »
I chose to remove the spring hinges, and use a hood-prop rod. A piece of angle was first affixed to the radiator support.
Offline chevn-up
« Reply #104 on: August 25, 2020, 05:43:44 pm »
Then to the salvage yard. This rod is from a 2002 S-10 truck. Looks factory, and no problem with the hood closing.
