Members Rides
project onion rings
7
8
9
10
14
Topic: project onion rings (Read 224559 times)
chevn-up
Re: project onion rings
Reply #105 on:
August 25, 2020, 05:44:49 pm »
ok.
macr0w
Reply #106 on:
September 14, 2020, 07:36:58 am »
Looks killer but, where's those sweet rims?
chevn-up
Reply #107 on:
September 15, 2020, 04:18:21 am »
Been busy renovating half of my house. The truck has been put on hold for now. These are a few older pictures that I'm just throwing out here for ya'll. When I get back on it, oh yea, the rims will be the new version truck.
chevn-up
Reply #108 on:
September 15, 2020, 04:21:02 am »
last one..
chevn-up
Reply #109 on:
November 25, 2020, 01:43:58 pm »
Finished up with the steering gear. The re-build was easy.
chevn-up
Reply #110 on:
November 25, 2020, 01:48:17 pm »
Adjusted the sector shaft and the input shaft pre-load. A spanner wrench makes it simple. I didn't have one, so I improvised. Worked out great.
chevn-up
Reply #111 on:
November 25, 2020, 01:51:00 pm »
I went from this original shaft...
chevn-up
Reply #112 on:
November 25, 2020, 01:51:49 pm »
To the Jeep shaft, no doubt.
chevn-up
Reply #113 on:
November 25, 2020, 01:52:40 pm »
Happy, Happy.
Shifty
I bleed Bowtie red...
Reply #114 on:
November 25, 2020, 02:34:09 pm »
98 C2500 ext cab longbed
chevn-up
Reply #115 on:
September 22, 2021, 06:54:26 pm »
Okay, everything blasted, painted, and pre-assembled. I won't bore you with all the details. Ya'll know how these front ends go together.
chevn-up
Reply #116 on:
September 26, 2021, 05:35:07 pm »
A weekend of wrench'n. Some highlights are 3" dropped spindles, 1" dropped springs, offset upper control arm shafts, (for more camber), aftermarket upper control arms, and raised stabilizer bar brackets.
Last Edit: September 26, 2021, 05:51:47 pm by chevn-up
chevn-up
Reply #117 on:
September 26, 2021, 05:37:51 pm »
Also added this door hinge spring that was missing since I've had the truck. Wow, the door stays open now.
Shifty
Reply #118 on:
September 27, 2021, 09:40:39 am »
chevn-up
Reply #119 on:
November 26, 2021, 03:47:14 pm »
Problem with the front brake hoses. The tall line is for my year truck (85). The "shorty" line is for a 1980 C10. I can't use the tall line because it hits my aftermarket spindle, making it impossible to install correctly. The other fits just fine. Problem solved. Just a heads-up, hoping this helps others.
7
8
9
10
14
Members Rides
project onion rings
