73-87 Chevy & GMC Trucks
Why is this loose?
Topic: Why is this loose? (Read 5619 times)
philo_beddoe
77 C-10
Why is this loose?
December 27, 2017, 09:47:30 pm »
Whats the trick on getting these stupid mirror cover things snug? Its clean on the inside meaning the tabs aren't rusted off, and the one bottom phillips screw is tight. But just this one side is giving me problems. Why didnt the engineers just use a top screw like the bottom instead of those stupid tabs?!
Behold, the day of the LORD cometh, and thy spoil shall be divided in the midst of thee. Zechariah 14:1
impco lpg
Re: Why is this loose?
December 28, 2017, 04:22:18 am »
i got two new mirrors and they are the same, one side of each mirror is not snug.
1983 cucv m1009 blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside 2wd 5.7ltr 350 lpg
December 28, 2017, 09:09:13 am »
Run a piece of masking tape across the top of the door so you do not scratch it. Remove the screw on the bottom, pop the cover up and tighten the bolts that secure the arm tension. When reinstalling the cover be sure the two tangs engage the back of the bracket while pulling the bottom over the tang. Make sure it is positioned correctly before reinstalling the screw.
philo_beddoe
77 C-10
Why is this loose?
December 28, 2017, 11:12:22 am »
Ok, will try that. The mirror never moves at all, nice and snug. Its just that cover. But i'll adjust those two tangs like you said.
If they were nice and snug at the dealership in 1977, then by-george i'll get'em that way today!
Last Edit: December 28, 2017, 11:16:44 am by philo_beddoe
December 28, 2017, 12:49:50 pm »
So the covers are just loose? I misread what you were saying. I would inspect the two clips, they're probably bent, out of position or broken.
philo_beddoe
77 C-10
December 31, 2017, 04:39:55 pm »
Yup...a little bent and/or out of pos. And yes, just the cover.
philo_beddoe
77 C-10
February 16, 2018, 04:03:34 pm »
Fixed! All i did was bend the two tabs out a little, now holds nice and snug, like it did back in '77.
Why is this loose?
