Author Topic: how do i measure pinion angle for shims?  (Read 7391 times)
Offline shaved80
« on: March 05, 2006, 05:12:00 pm »
i asked on fullsizechevy.com with no response...maybe someone here can help out.
one thing i noticed though, is it only vibrates if i accelerate slowly, not at a faster than normal speed
Offline DnStClr
Re: how do i measure pinion angle for shims?
« Reply #1 on: March 09, 2006, 12:18:00 am »
I think you're more interested in the drive shaft angle. They can be checked with an inclinometer.  Does this site help?
www.drivetrain.com/driveline_angle_problem.html
Don
87 Chevy Silverado
Offline roundedline
« Reply #2 on: March 09, 2006, 12:30:00 pm »
Put an angle finder on the output shaft yoke and take a reading and them put it on the rearend input shaft and take a reading.  Technically they should be the same.
The reading for the pinion angle should be between 1 and 4 degrees down from the driveshaft.  Optimumly it should be 3-4 for a leaf setup.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline DnStClr
« Reply #3 on: March 10, 2006, 12:11:00 am »
Have you checked the U- joint for looseness?
Don
87 Chevy Silverado
